We have a pair of these dish washers and one seems to be jinxed. On the unit in question we replaced the motor early on and last year had the controller board replaced.
This week we noticed some small leaks coming from the control surface (buttons) and the unit stopped working. Our friendly appliance guy come out to look at it and said that water appeared to be leaking down into the door compartment due to interference between the door and the screws going into the underside of the counter.
He tightened up the screws and the unit worked but some functions were not available (i.e. light load and rinse only). He checked the power and after reconnecting everything we ran a cycle without incident. Today, nothing. I removed the inner cover and verified that there is power going to the door latch (so not fuses, breakers, or wall switches).
Any clues would be appreciated.
RG
