| » Normal Wash Light Blinking |
Model Number: 665.17012402 Brand: Kenmore Age: 1 - 5 years
I've had my Kemore dishwasher for about 2 years. Recently the Normal Wash light started blinking about 18 times straight, hesitates momentarily, and continues the blinking cycle again.
I first unplugged the original board & plugged it back in & it worked for a week or so. But, then it started the blinking again. That little trick no longer works. I replaced the circuit board with a new one. The problem still exists. I tried another suggestion of toggling HI TEMP WASH/HEATED DRY for 5 minutes. Nothing happened. I read also the it could be the heating coil or maybe another sensor. I haven't tried any of these as of yet. I wouldn't know where to look. Does anyone have any idea what I need to do to get this working again? I am totally stumped on this. Thanks! |
The LED, flashing rapidly means the control board sensed a stuck key or shorted circuit in key pad.
In order to fix the problem, the console has to be replaced. - The part number for the black console AP3777661 - The part number for the white console AP3777709 - The part number for the biscuit console AP3777710 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Okay, I'll give that a try. Another $120 down the drain.
The part was out of stock on the link you provided. As much as I hate ordering through Sears, I went ahead & did. I took apart the keypad to see if maybe some water crossed the contacts. It didn't come apart very neatly, but I was able to wipe some moisture away & get it to start for a moment. It cut back out after awhile. I babysat the thing to get a complete load washed, but this definitely is not the way I want to do my dishes. Thanks for you assistance, Gene. I'll post back my results from the new part. |
| Display Modes | |
| Dishwasher lights blinking and wont start | megger2u | Dishwasher Repair | 1 | 11-29-2007 01:47 PM |
| Kenmore - Clean Light blinking | lskcooper | Dishwasher Repair | 1 | 11-05-2007 02:50 PM |
| Washer agitates normal then slows down and stops. | jnaylor | Washer Repair | 3 | 10-22-2007 08:14 PM |
| I can hear water behind the drum is this normal? | repowoman | Washer Repair | 0 | 10-06-2007 01:58 PM |
| Can not select wash cycle - stuck on scrub wash | luke | Dishwasher Repair | 0 | 08-20-2007 09:38 AM |
