Discuss
Normal Wash Light Blinking
 in
Dishwasher Repair
I've had my Kemore dishwasher for about 2 years. Recently the Normal Wash light started blinking about 18 times
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Normal Wash Light Blinking
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-03-2007, 06:56 PM
kevlarnovack kevlarnovack is offline
Junior Member
kevlarnovack is on a distinguished road
Default Normal Wash Light Blinking
Model Number: 665.17012402   Brand: Kenmore   Age: 1 - 5 years
I've had my Kemore dishwasher for about 2 years. Recently the Normal Wash light started blinking about 18 times straight, hesitates momentarily, and continues the blinking cycle again.
I first unplugged the original board & plugged it back in & it worked for a week or so. But, then it started the blinking again. That little trick no longer works.
I replaced the circuit board with a new one. The problem still exists.
I tried another suggestion of toggling HI TEMP WASH/HEATED DRY for 5 minutes. Nothing happened.
I read also the it could be the heating coil or maybe another sensor. I haven't tried any of these as of yet. I wouldn't know where to look. Does anyone have any idea what I need to do to get this working again? I am totally stumped on this.
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 10:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The LED, flashing rapidly means the control board sensed a stuck key or shorted circuit in key pad.
In order to fix the problem, the console has to be replaced.
- The part number for the black console AP3777661
- The part number for the white console AP3777709
- The part number for the biscuit console AP3777710
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-05-2007, 05:05 PM
Junior Member
Okay, I'll give that a try. Another $120 down the drain. The part was out of stock on the link you provided. As much as I hate ordering through Sears, I went ahead & did.
I took apart the keypad to see if maybe some water crossed the contacts. It didn't come apart very neatly, but I was able to wipe some moisture away & get it to start for a moment. It cut back out after awhile. I babysat the thing to get a complete load washed, but this definitely is not the way I want to do my dishes.
Thanks for you assistance, Gene. I'll post back my results from the new part.
  #4 (permalink)
Old 12-11-2007, 05:13 PM
Junior Member
Thumbs up Resolved
Gene,
Thanks again for the assistance. Replacing the panel resolved my issue. I was hoping for a less expensive option, but I can wash dishes once again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher lights blinking and wont start megger2u Dishwasher Repair 1 11-29-2007 12:47 PM
Kenmore - Clean Light blinking lskcooper Dishwasher Repair 1 11-05-2007 01:50 PM
Washer agitates normal then slows down and stops. jnaylor Washer Repair 3 10-22-2007 07:14 PM
I can hear water behind the drum is this normal? repowoman Washer Repair 0 10-06-2007 12:58 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
