Discuss
GE Profile QPIII
 in
Dishwasher Repair
I never get the dishwasher to drain , the bottom is always full I checked hoses and they are not plugged ,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Profile QPIII
  #1 (permalink)
Old 12-03-2007, 06:10 PM
kevlar kevlar is offline
Junior Member
kevlar is on a distinguished road
Default GE Profile QPIII
Model Number: GSD4330Z04WW   Brand: GE   Age: 5 - 10 years
I never get the dishwasher to drain , the bottom is always full I checked hoses and they are not plugged , I changed the Drain Solenoid and it still is not draining . Is there something I am missing? Is ther a impeller somewhere??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 06:29 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
Check inside the dishwasher at the back of the tub, there should be a long filter with 4 1/4 head screws. Remove that filter and it will expose a piston/nut assembly. It will unscrew counter clockwise with a pair of needle nose pliers. You may find that there is a rubber plunger type of material that has disintagrated over time and that piston/nut will need to be replaced as that causes a slow to no drain situation when faulty. Hope this helps.
  #3 (permalink)
Old 12-03-2007, 06:46 PM
Junior Member
Default thanks
Hey i just took out the filter and got the piston part out it seems like it works but i see no reubber parts i mena the spring is fine and there is some white residue i assume that is the rubber but if it is open does that not drain or does it use a vacuum type reaction . anyway where can i get the part? thanks
  #4 (permalink)
Old 12-03-2007, 06:49 PM
Senior Expert
APP Volunteer
Default
That white residue is what's left of the rubber seal which is part of the piston/nut. Replace that part and it should drain 100%.
  #5 (permalink)
Old 12-03-2007, 06:54 PM
Senior Expert
APP Volunteer
Default
The part # is WD24X10018. The part costs no more than 10.00 canadian. Any appliance part dealer will be able to help you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile Arctica nguyenbn Refrigerator & Freezer Repair 14 08-14-2008 09:47 AM
GE Profile Not Getting Water JeffZ Dishwasher Repair 0 12-01-2007 01:31 PM
oil leak from under ge profile washer husker Washer Repair 0 10-14-2007 01:21 PM
GE profile blew up bettye Microwave Repair 2 10-12-2007 06:05 PM
GE Profile Cas range PJCIII Oven Repair (including Ranges and Cooktops) 3 08-27-2007 10:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
