Discuss
dishwasher smells like it's burning
 in
Dishwasher Repair
My name is Garrett. My dishwasher smells like something is burning the last 2 times it has run. It has
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher smells like it's burning
  #1 (permalink)
Old 09-21-2011, 09:55 PM
Junior Member
glmy78 is on a distinguished road
Default dishwasher smells like it's burning
Brand: Bosch   Age: 1 - 5 years
My name is Garrett. My dishwasher smells like something is burning the last 2 times it has run. It has always had a problem with the soap dispensor opening when it runs. The electric is also a little touchy as the power cord was just long enough to connect, so sometimes it loses power for a second. Any ideas on why it would smell like burning when it runs would be much appreciated.
Ads By Google
  #2 (permalink)
Old 09-22-2011, 08:53 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Garret,
The first thing you need to resolve is, your power supply, Loose connections, fluctuating power , etc. create all kinds of overheating, low or high wattage problems etc. You really need to solve that issue first. A short, heavy duty, extension cord or a longer power cord may be a easy method to solve the issue.
Make sure the dishwasher is filling properly on all cycles, It could be the water heating option trying to heat the water, and theres none there. Otherwise we're back to possible damage to electrical components, due to the power supply issues.
Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-26-2011, 08:19 PM
Junior Member
Default I figured it out.
Quote:
Originally Posted by Joe / APP Team View Post
Garret,
Thanks for the advice. I got a chance to look at it and the hot wire had been taped on to hold it tight because the screw holding the hot wire was stripped. It was duct tape and it was burning. That was the smell. So i removed the duct tape and put a new screw in to hold the hot wire. I ran the dishwasher and there was no smell. Thanks for your help.
  #4 (permalink)
Old 09-27-2011, 06:27 AM
Senior Expert
Default
Glmy,
Great job,
We're glad we were able to assist.
Hopefully, all will be good from here on out.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor smells as if burning 180rae Washer Repair 3 07-24-2011 08:19 AM
dry smells like burning again ch0mpie Dryer Repair 3 04-26-2011 06:56 AM
dry smells like burning again ch0mpie Dryer Repair 0 04-24-2011 06:19 PM
oven smells when burning crs76 Oven Repair (including Ranges and Cooktops) 0 01-03-2011 06:14 AM
belt smells like burning fedexsteve Washer Repair 1 09-08-2008 04:16 PM
