Discuss
Drain manually required sometimes
 in
Dishwasher Repair
Ocassionally the dishwasher collects water in the bottom and fills up to the point where it leaks on the floor
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain manually required sometimes
  #1 (permalink)
Old 12-02-2007, 08:35 PM
mark Campbell mark Campbell is offline
Junior Member
mark Campbell is on a distinguished road
Default Drain manually required sometimes
Brand: Whirlpool   Age: 1 - 5 years
Ocassionally the dishwasher collects water in the bottom and fills up to the point where it leaks on the floor thriough the bottom of the door. I can hit the drain button and it drains fine, but I will come back later and more water starts collecting. What is causing the water to collect or backup in the bottom of the dishwasher? I checked the hose to the disposal and it is installed correctly and not clogged. I shut off the water supply and it still collects. It can go for weeks without doing this, and then it will start again.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 09:22 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
If you turned the water supply off then you have eliminated a bad fill valve. That leaves the drain line as the only source of water to the unit. The drain line should run up to a high point under the counter before it connects to the disposer. If the line runs up to the disposer, it is possible for water to filter back into the unit over a period of time.
TechnicianBrian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitator Won't Turn Manually? CAN I DO IT Washer Repair 1 07-27-2007 10:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
