Discuss
Bosch SHU5314 has "F" in display
 in
Dishwasher Repair
It is making a strange sound when compared to normal running. There does not seem to be any water in
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch SHU5314 has "F" in display
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-02-2007, 06:22 PM
tpshea tpshea is offline
Junior Member
tpshea is on a distinguished road
Default Bosch SHU5314 has "F" in display
Model Number: SHU5314   Brand: Bosch   Age: 5 - 10 years
It is making a strange sound when compared to normal running. There does not seem to be any water in the bottom.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 02:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The "F" error code means there is a filling problem.
It could be the water shut off valve under the sink, the dishwasher water inlet valve or the power from the control board to the water inlet valve.
- The part number for the water inlet valve AP3783031
- The part number for the control board AP2802870
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-04-2007, 06:23 PM
Junior Member
Default
Gene,
Thanks much for the help. Are these parts difficult to replace? I am very good with tools, I have worked on computer equipment for the last 30 years. Also, are there any other items that should be considered for replacement as part of normal maintenance?
Thanks again,
Tim
  #4 (permalink)
Old 12-04-2007, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The hardest part is to diagnose which part is bad.
The rest is much easier.
The control board is in the door and thew water inlet valve is under the dish washer in front. In most cases you do not have to remove the dishwasher from the cabinet.
__________________
  #5 (permalink)
Old 12-05-2007, 05:53 AM
Junior Member
Default
Gene,
Thanks much for your advice! I truly appreciate it.
Tim
  #6 (permalink)
Old 12-12-2007, 08:37 PM
Junior Member
Default
Well, I thought it was fixed. I replaced the control panel that I purchased here, and for the first 2 days all seemed to be well. Ran the dishwasher this evening and it counted down to 26 minutes and never went any farther. I found the instructions on setting it to complete mode, and it finally finished after I had pressed the two buttons. It also is growling fairly loud compared to normal. Circulation pump? Thanks in advance.
  #7 (permalink)
Old 12-13-2007, 08:09 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
usually on this model when the control unit ( bosch part # 266746 ) is bad , burnt relay on the board, it will get stuck cause heating has not occured and temp never achieved. need to determine if there may be a suds problem in the d/w .. run it on an economy program with very little detergent ( 15 ml or less ) ... Never pre-rinse, especially with a sponge w/ soap on it (remember SOAP is a d/w 's greatest enemy !! ) And make sure enough water is coming into the d/w.. if you have a clogged inlet valve , you may not be getting enough water and that will cause a louder circ pump as well as a poor heating condition. This will cause the d/w to "hang-up" at 26 , 13, 11 or 1...
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"CLEAN" cycle light always flashing Tadek Dishwasher Repair 9 07-22-2008 05:01 PM
Kenmore (Whirlpool) washer "bang" noise when spinning dadasmatta Washer Repair 2 12-22-2007 07:34 PM
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 07:18 PM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 07:16 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 06:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
