Discuss
Dishwasher doesn't drain completely
 in
Dishwasher Repair
Help!! We just had a dishwasher installed a few days ago. It runs fine except there is still water in
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher doesn't drain completely
  #1 (permalink)
Old 12-02-2007, 04:49 PM
melindac melindac is offline
Junior Member
melindac is on a distinguished road
Default Dishwasher doesn't drain completely
Model Number: FDBB2455FBO   Brand: Frigidaire   Age: Less than 1 year
Help!! We just had a dishwasher installed a few days ago. It runs fine except there is still water in the bottom after it finishes. What to do ???????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 05:42 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
If you just had it installed, maybe have the installer return and check it out. The drain hose on those models must be run up to a high point under the counter and then connected to the disposer or drain. If the hose just runs up to the connection, water can return to the DW after the drain pump stops.
TechnicianBrian
  #3 (permalink)
Old 12-04-2007, 09:34 AM
audreyeliz audreyeliz is offline
Junior Member
audreyeliz is on a distinguished road
Default
I have kind of the same problem. Water at the bottom of the machine but everytime the drain cycle should start i hear a click, the motor isn't turning but is humming and after 5 seconds another click and nothing. I took the pump/motor out nothing is blocked and the impellers run freely. My dishwasher is a Whirlpool Du943pwkq0 installed 5 years ago. Do i need to replace the pump?
  #4 (permalink)
Old 12-04-2007, 12:12 PM
Senior Expert
APP Volunteer
Default
The pump on your dishwasher will spin one direction to wash and reverse to drain. The best way to troubleshoot this is to remove the access panel and look for the connector to the pump. It will have blue, grey, yellow and red/black wires. If you can get access to a volt-ohm meter, connect the meter to the grey and red/black wires and put the machine into drain. You should read 120volts approx. If you do and the pump doesn't operate, then you are looking at a motor. If you do not have voltage at those points, you are looking at a control assembly. And if you do not have a meter, you are most likely looking at a motor, but I would get a meter just to make sure.
TechnicianBrian
  #5 (permalink)
Old 12-05-2007, 07:07 PM
Junior Member
Default
Thankx for the quick reply TechnicianBrian. I checked the voltage between the grey and yellow at the motor and i read 2 to 5 volts. I open the inside door to access the control board and ran the same test. Same readings. So you think i should replace the control board? Thank you in advance.
  #6 (permalink)
Old 12-05-2007, 07:38 PM
Senior Expert
APP Volunteer
Default
Before you get to far, I made an error in the wire colors. Unplug the motor from the harness and do a resistance check of the motor. Between the grey and red/black wires you should read approx 5 ohms and between the blue and red/black wires you should read approx 3 ohms. This will verify the electrical operation of the motor. If either check reads an open circuit, the motor is bad. Then reverify the voltage between the grey wire and the red/black wire and then between the blue wire and the red/black wire. Do this with the motor disconnected from the harness. You should have 120vac on each reading you take when you put the unit into drain. Make sure the unit is in drain and the door is closed. If you now don't have the voltage, then it's the control. Sorry for the misinformation on the first post, I was working on a similar DW and was looking at the wrong tech sheet.
TechnicianBrian
  #7 (permalink)
Old 12-06-2007, 02:42 PM
Junior Member
Default
Ok i checked and between grey and red/black i have about 3 ohms and the same between blue and red/black. For the voltage i have 120 v. between blue and red/black but only 43 v. between grey and red/black. I should replace my control board? Thank you.
  #8 (permalink)
Old 12-06-2007, 04:35 PM
Senior Expert
APP Volunteer
Default
Looks like a control board. If you chose to replace it, take a look at the parts breakdown for the door as to what to take apart to get to the control. It isn't as obvious as you would expect. Good Luck
TechnicianBrian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher won't drain walknite Dishwasher Repair 4 11-20-2008 04:08 PM
dishwasher won't drain ddavis Dishwasher Repair 1 11-25-2007 05:47 PM
dishwasher won't drain completely ynot Dishwasher Repair 1 10-24-2007 11:11 AM
Whirlpool dishwasher does not drain Sdj Dishwasher Repair 6 10-09-2007 11:32 AM
Bosch Dishwasher Won't Drain jshoe01 Dishwasher Repair 2 09-06-2007 11:27 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
