Discuss
Bosch Control Module failure?
 in
Dishwasher Repair
The dishwasher stopped mid-cycle, no lights on at all. My wife had thought she had smelled a burning smell in
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Control Module failure?
  #1 (permalink)
Old 04-17-2009, 01:00 PM
Junior Member
smsoe is on a distinguished road
Default Bosch Control Module failure?
Model Number: SHU 9915 UC11   Brand: Bosch   Age: 1 - 5 years
The dishwasher stopped mid-cycle, no lights on at all. My wife had thought she had smelled a burning smell in previous uses, but I'm not sure. I removed the control module, all looks good, nothing smells burnt. It acts as if the control module power source is gone; the 120v input to the dishwasher is fine. I'm assuming the control module has it's own DC power source. I reinstalled it, applied AC power, pushed the on/off switch to ON and the lights came on for a short time, then started to flicker, then went out. With the door closed, I could hear a relay on the module clicking but nothing happened. I'm guessing that the module needs replacing, but it's quite expensive and it would be good to have a second opinion before I purchase a new one. Is there some other part in the dishwasher that could load down the module and cause the lights to go out?
Thanks for your help!
Ads By Google
Related Models
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
  #2 (permalink)
Old 04-17-2009, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if there is 120VAC from the "on-off" switch to the control module while the door is locked and the switch is "on".
If there is correct voltage then the control module most likely is bad.
If the voltage is incorrect then you have to trace the power from the power cord connection (under the dishwasher) to the control module.
You also can use the troubleshooting manual from one of our previous posts: bosch dishwasher troubleshoot manual
Here are the breakdown diagrams and Replacement parts for BOSCH SHU9915 UC/11 (FD 8002-8003) | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-17-2009, 07:25 PM
Junior Member
Default It was an AC Power problem, after all
The symptoms pointed to the control module (flickering lights) but the real culprit was the connection to the power cord in the junction box behind the kick plate. One wire nut had actually melted, leaving maybe one strand of wire still connected! Not enough to support the needed current but enough to barely power the lights. Poorly done installtion 5 years ago and it just now failed. Re-connected the power cable with new wire nuts and it works fine!
  #4 (permalink)
Old 04-18-2009, 04:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are glad you were able to fix it and it was that simple.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dryer control module JoanS Dryer Repair 0 08-21-2009 03:33 PM
Bosch Dishwasher - Control module failure? tgkleman Dishwasher Repair 0 06-11-2009 06:13 AM
New Bosch Control Module slightly different TAC Dishwasher Repair 3 01-02-2008 06:41 PM
Bosch Control Module - programming WayneK Washer Repair 0 09-26-2007 03:43 PM
Bosch control module cmsross Dishwasher Repair 1 09-13-2007 08:42 PM
