raj8567
#1 Posted : Thursday, April 16, 2009 4:21:01 AM(UTC)
raj8567
My GE dishwasher emits a steady beep and nothing else no lights will not run. I changed the computer and nothing changed
Happy_15010
#2 Posted : Thursday, April 16, 2009 4:16:54 PM(UTC)
Happy_15010
I have the same problem as the above user. Here's more details.
GE Profile dishwasher model PDW8200J03WW
After power outage, dishwasher came back on and just emitted steady beep, no lights or control response. I turn off the main breaker for a while, no luck.
I then read this forum and bought a replacement control module from Appliance Parts Pros, WD21X10215, (order #644145)
After installing the module, no difference. I get the same long steady beep. What should I replace next? Thanks for the help.
optimist
#3 Posted : Saturday, April 18, 2009 8:31:34 AM(UTC)
optimist
I have a GE Monogram that had the same problem. It was the keypad control strip.
Happy_15010
#4 Posted : Saturday, April 18, 2009 8:30:58 PM(UTC)
Happy_15010
Thanks Optimist. I know the part you are talking about (front panel piece with membrane push buttons, connects via ribbon cable to the control module) but I don't see "control panel" listed on the parts list.
Is is called the Escutcheon? I think this is it. (Just didn't want to buy the wrong thing again). Thanks for the help.
Enlarge Photo
Escutcheon bowed - Color: White
Part Number: AP3794428 made by GE
optimist
#5 Posted : Sunday, April 19, 2009 2:35:12 PM(UTC)
optimist
I can't be exact w/o knowing what model # you have, but you should be able to locate it from the parts search tool here. For example, here's what I found for my GE Monogram...
Replacement parts for GE ZBD6880K00SS | AppliancePartsPros.com
It's part # 719 on the diagram.
optimist
#6 Posted : Sunday, April 19, 2009 2:39:52 PM(UTC)
optimist
Uh, duh. Sorry, I see that you did post your model #. I think it must be the Escutcheon. There looks to be a ribbon connector hanging off it in the diagram: Replacement parts for GE PDW8200J03WW | AppliancePartsPros.com
Shame that you have to replace the whole thing, but it doesn't look expensive.
Happy_15010
#7 Posted : Sunday, April 19, 2009 6:13:20 PM(UTC)
Happy_15010
Yeah, that's what I kinda figured as well. Thanks for looking at it too. I'll order it tomorrow and see how it goes. Thanks again.
Happy_15010
#8 Posted : Saturday, May 23, 2009 6:58:10 PM(UTC)
Happy_15010
Just wanted to let everyone know, that fixed the problem! Steady Beep often means the control panel (Escutcheon).
kkanuck
#9 Posted : Friday, July 13, 2012 1:14:24 PM(UTC)
kkanuck
Can anyone by chance verify if the keypad membrane is not connected electrically to the Control module that a steady beep is the symptom? I have a dead keypad, no lights ever, and I get the steady beep no matter if it is plugged into the control module or not, so if the control module required the keypad ribbon to be plugged into it, then it would, indicate I have a faulty keypad membrane, however if the control module does not require the keypad to be plugged into it to prevent this steady beep, then I may have another issue. Just trying to not fix a part if it is not broken so to speak...
Angecolange
#10 Posted : Monday, July 1, 2013 1:23:03 PM(UTC)
Angecolange
I have replaced both circuit board and control board as they came as a pair in one box. Clean light just blinks...nothing else will work?!?! Any ideas of how to reset this GE dishwasher model # GLD4209L15SS....thanks!
