The electrical control panel and fuse burned out. The control panel number is 8530909. I ordered #8564542 since this was listed as a direct replacement. I plugged it in along with the new fuse 8193762. I turned on the power and shut the door. The display did not show numbers, only a rotating line. When I pressed start the washer filled with water. The arm rotated for a few seconds and then the dishwasher stopped. I pressed cancel to drain the water.
As far as I can tell I hooked all the cables correctly. Since this is a replacement board, is there something I'm missing?
