Discuss
water splashing over front lip of tub
 in
Dishwasher Repair
Ok, so I am not stupid - I actually used to be a dispatcher for Maycor, so I know a little
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » water splashing over front lip of tub
  #1 (permalink)
Old 12-01-2007, 03:53 PM
julieb julieb is offline
Junior Member
julieb is on a distinguished road
Question water splashing over front lip of tub
Model Number: DU840SWKQ0   Brand: Whirlpool   Age: 1 - 5 years
Ok, so I am not stupid - I actually used to be a dispatcher for Maycor, so I know a little bit about troubleshooting appliances. But this one has had the factory service guys stumped too.
I took off the door cover and access panels to try to find the source of leaking water. While it is running you can look into the place where the door liner sits inside the tub and see water swirling. Sometimes, though it swirls over the edge and spills out. (It's NOT overfilling.) The repair guy came out and he was stumped. The guy at his headquarters that he was on the phone with was stumped. For lack of anything else to do, they replaced the door liner. This fixed it (???) while he was here. The very next time I ran it, it leaked, so obviously, it DIDN'T fix it. I've been narrowing it down myself...
I think the water is actually coming through the vent holes in the bottom of the door. I thought maybe (since I have very hard water) my spray arm was clogged, making it spray wierdly. I just took it off, and it looks fine. BUT I am wondering...is it supposed to be water tight on the seams along the side? Do I possibly need a new spray arm? I am thinking maybe water is shooting out the end of the arm (rather than just the holes) and coming out those vents.
Sorry for the LONG story...please somebody help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 03:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if the tower protector (#2 on the dish rack break down diagram) and the water diffuser (#11 on the dish rack break down diagram) are in place.
Check if the vent screen (#12 on the inner door break down diagram) is not clogged.
- Here are the break down diagrams for the Whirlpool dishwasher Model DU840SWKQ0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-03-2007, 09:18 AM
Junior Member
Default
nope, they're all fine. Also, here's a further clarification of symptoms.
It seems to leak worse the longer it washes. In other words, it's dry on the first pre-rinse and beginning of light wash, but by the end, water is just really dripping heavily. This is most likely the reason is seemed to stay dry while the serviceman was here. He didn't run a full cycle.
Hope that helps, and thanks for YOUR help.
  #4 (permalink)
Old 12-03-2007, 12:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately this is beyond my expertise.
Hopefully someone else on the forum could help you to solve this problem.
__________________
  #5 (permalink)
Old 12-04-2007, 08:49 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
its possible there is an excessive amount of water accumalating in tub .there shoud be about 2 1/2 inches of water . check level of water when it starts to leak. does the water drain completly when you cancel it.if this machine has float cup +switch .check to see float cup is not clogged with detergent . that can fool the water valve to stay open longer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front Drum Bearing cassie31899 Dryer Repair 3 11-02-2007 12:14 PM
removing cover off front of water/ice dispenser need4help Refrigerator & Freezer Repair 1 11-02-2007 11:48 AM
Water leak on front side of ice maker after fill trentrb211 Refrigerator & Freezer Repair 0 10-22-2007 11:53 AM
need to get front cover of fdryer off kanderson Dryer Repair 1 09-22-2007 01:18 PM
front loader not draining distress Washer Repair 1 09-14-2007 03:24 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
