kmehrer
#1 Posted : Wednesday, April 15, 2009 10:00:04 AM(UTC)
kmehrer
I have taken apart all the piping etc from the motor to all the spray arms and the lower arm works fine and is clear of debris, the midlevel arm is free of debris but gets no water pressure...ideas? I have cleared out all debris from the traps and the food grinder etc, it seems that there just isnt enough force to push the water up to the higher spray arm anymore...we have grinding sounds as well.
#2 Posted : Wednesday, April 15, 2009 11:34:10 AM(UTC)
In order to provide most accurate advice we need the complete model number of the dishwasher.
kmehrer
#3 Posted : Wednesday, April 15, 2009 12:29:18 PM(UTC)
kmehrer
Thanks for the response. We have Whirlpool Gold Mod # GU1200XTL01
#4 Posted : Wednesday, April 15, 2009 6:24:00 PM(UTC)
Check the chopper assembly (#6 on the diagram) and perform other troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...hirlpool-dishwasher.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLQ1 | AppliancePartsPros.com
kmehrer
#5 Posted : Tuesday, April 21, 2009 4:48:04 AM(UTC)
kmehrer
It worked, thanks. As an aside, I bumped the value at the left hand side of the unit when I was pushing it back into the counter, apparently it was loose and I turned the unit on and water was everywhere!
It didnt appear to be that important of an attachment, a drain valve etc, but I pulled the unit back out, reattached the cover and everything is great.
thanks for the help!
#6 Posted : Tuesday, April 21, 2009 4:23:56 PM(UTC)
You are welcome. We are glad you were able to fix it.
