Machine has power...cycle lights lite up... press start/cancel button an lites go out an will not start... Itook front panel off check door latch locking,still not start.
any ideas on next step
thx smitty
yes to door latch, an no to any sounds at all. no humming,motor/restrictions,cycles sounds... just lites on but go off when pressing start
Measure the voltage between the Black and the White wires from the door switches to the control board while the switches are engaged. If there is the correct voltage then the control board has to be replaced. - The part number for the control board is AP3880764 Gene.
thk you gene, i will b going there sat. to test the lines and thier current. will let you know then my status. smitty
