[FONT='Times New Roman']I continue to get a white slime build up in my dishwasher. When it first appeared it looked like someone had left a can or bottle with a label on it and the label has come off and clogged the water jets. I knew that something wasn't working right because after washing all plastic ware (glad ware etc) has a waxy opaque film deposited on it. I took the entire innards of the dishwasher apart and found this thick paper like white slime coating everything. In some places (under the water level float and strainer basket) it would build up as a thick gooey deposit. I scrubbed and cleaned out all of it that I could. I even used scrub brushes to reach into the water jets. Then I ran several bleach solutions through my dishwasher. Now approximately 3 months later it is back and coating everything again. It has a foul smell and once again the plastic is left with a film on it.[/FONT]
