| » sump pump and or drainage trouble |
Model Number: SHU8805UC Brand: Bosch Age: 5 - 10 years
I bought in Dec. 2002 this dishwasher.
The water comes in is swirls around fine but it does not drain . Ichecked the sink drain and it is fine. To get to the solenoid valve or the sump pump do I need to remove door and or how to go to it? Thanks Related Models |
Before you will tear down the dishwasher I would recommend to check the air gap on top of the sink and the drain hose all the way from the dishwasher to the air gap, or to the garbage disposer if there is no air gap installed.
Here are the breakdown diagrams and Replacement parts for BOSCH SHU8805 UC/12 (FD 8105-) | AppliancePartsPros.com You also can use the troubleshooting instructions from one of our previous posts: bosch dishwasher troubleshoot manual Gene.
__________________
Professional appliance repair in Orange County, California. |
Quote:
Is there another air gap anywhere? Last edited by CELINE : 04-15-2009 at 05:49 PM. |
I decided to run a cycle in a bucket and to my astonishment it was draining???It seems that at the junction with the sink debries had collected enough to prevent drainage.
Thank you Gene for making me double check the obvious. I am happy I did not need to changed the sump pump because they did not leave us much space to work. It is like they think we need to save space like it was on a space kraft or that we carry our dishwasher were ever we go. It was my first experience using a forum and it won't be the last. Thanks everybody! Last edited by CELINE : 04-15-2009 at 08:06 PM. |
You are welcome. I'm glad it was not very complicated.
__________________
| Display Modes | |
| Drainage Failure, Sump Pump Replacement | CELINE | Dishwasher Repair | 1 | 04-14-2009 01:38 PM |
| Replacing sump pump gasket | cardzfan | Dishwasher Repair | 1 | 10-02-2008 07:44 PM |
| Drainage not working | John Toomer | Dishwasher Repair | 3 | 07-09-2008 01:26 PM |
| Drainage | TOMMYL | Dishwasher Repair | 0 | 07-08-2008 01:53 PM |
| Drainage Problem | sfreem33 | Dishwasher Repair | 0 | 08-25-2007 01:44 PM |
