Discuss
Bosch DW stuck in wash cycle?
 in
Dishwasher Repair
Just found this forum and I hope someone can point me to which part may need to be changed: I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch DW stuck in wash cycle?
  #1 (permalink)
Old 04-13-2009, 10:07 AM
greway greway is offline
Junior Member
greway is on a distinguished road
Default Bosch DW stuck in wash cycle?
Model Number: SHX46A02UC/26   Brand: Bosch   Age: 1 - 5 years
I have a Bosch DW that when started stays in wash cycle. This is the one where the controls are hidden on the top of the door, no timer switch to turn to start. Starts and fills fine, emptys soap container, but does not drain and advance to rinse. After ~30 minutes of washing I have to press the two buttons to get it to drain, then run the rinse and hold cycle to get dishes rinsed, but this won't go into dry cycle.
This is a brand new problem as for ~3 yrs worked perfectly. This only started Thursday night (was 'stuck' in wash mode for 4 hours, before I realized was still running!). Work around not really satisfactory, but beats hand-washing all the dishes for a family of 4 every night!
Any thoughts? Control panel? Water temp sensor?
TonyG
Related Models
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Amana SL25MW Ref - SXS/I&W
Amana SLD22JB Ref - SXS/I&W
Amana SLD22MB2L Ref - SXS/I&W
Amana SLD22MB2W Ref - SXS/I&W
Amana SLD22MBG Ref - SXS/I&W
Amana SLD22MBL Ref - SXS/I&W
Amana SLD22MBW Ref - SXS/I&W
Amana SLD25J Ref - SXS/I&W
Amana SLD25JB Ref - SXS/I&W
Amana SLD25JP Ref - SXS/I&W
Amana SLD25M2G Ref - SXS/I&W
Amana SLD25M2L Ref - SXS/I&W
  #2 (permalink)
Old 07-22-2009, 09:42 PM
bill_s bill_s is offline
Junior Member
bill_s is on a distinguished road
Default
I have the same problem. Have had any success in solving. I wonder if it is the heater as the water does not seem that hot.
  #3 (permalink)
Old 07-23-2009, 05:33 AM
Junior Member
Default
I replaced the control module. There is a solder joint that overheats and breaks on the board. You can re-solder it or replace unit. I replaced the unit, took about 10 minutes to swap out.
  #4 (permalink)
Old 07-23-2009, 02:10 PM
Junior Member
Default
I will take a look. Soldering would be a quick fix for sure. I also have no hot water - so I am still wondering if it is a heater problem. Was the solder joint obviously broken ??
Do you recall if you had hot water - mine is just luke warm to cool.
Thanks for the response.
  #5 (permalink)
Old 07-23-2009, 09:35 PM
Junior Member
Default
Thanks for the info. I was going to look at the module before I ordered a new one. Easier to replace the module than the heater unit. Took a few minutes to figure out those bloody snap clips when disassembling, however once apart and checking the circuit board there was obviously a relay with a post that was blackened (over heated) and had become disconnected from the board due to loss of the solder. A quick touch of silver solder and we are back in business.
Thanks again for the lead.
Bill
  #6 (permalink)
Old 10-29-2009, 01:32 PM
sbk101 sbk101 is offline
Junior Member
sbk101 is on a distinguished road
Default
I'm so glad I found this forum. My Bosch shx46... has the same problem. It is exactly 3 years old. I will verify soon if it is the control module. Where did you buy the replacement? Is it the same as the Circuit board that is under warranty for 5 years? Sounds like there is a defect in this thing if the relay that controls the water heater element burns out. something is getting too hot and who is to say the new one wont do the same thing.
Thanks guys.
  #7 (permalink)
Old 10-30-2009, 07:38 PM
Junior Member
Default
I soldered and it lasted 2 or three cycles. I bought a new module - call bosch and they will direct you to a local parts supplier.
  #8 (permalink)
Old 10-31-2009, 11:32 AM
Junior Member
Default
Quote:
good to know. I called Bosch yesterday and asked to exchange my circuit board but they would only set up service call. My board is still under warranty. I soldered it yesterday since it had the same problem as yours. Has the new board lasted for you? Do you think they fixed the problem?
I can either order a new one and install it myself, or I can can let the Bosch repair guy came and exchange it for me. I'll pay the same amount.
Any suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer stuck in wash cycle sandracilia1@hotmail.com Washer Repair 0 02-10-2009 02:38 PM
washer stuck in wash cycle sandracilia1@hotmail.com Washer Repair 0 02-10-2009 02:33 PM
Stuck in Short Wash Cycle mbonen Dishwasher Repair 0 01-23-2009 08:17 AM
Stuck in wash cycle Sgate Dishwasher Repair 1 10-24-2008 08:20 AM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 09:38 AM
