My Fridgidaire DW (PLD4555RFC2) will not complete a cycle. After washing for around 40-50 minutes, the selector light for the "dry" cycle selection begins to cycle around on it own, between air-heated-sahara. While the light cycles around, the time remaining in wash cycle also flickers between 93 and 99+. Then after a minute or two of this happening, the dishwasher just shuts off and LED goes blank. The water inside at this point is *very* hot and steamy. It seems the DW can't be restarted properly until things have cooled a bit. Once cool, the same thing will happen. If attempted to restart while hot, it will just flicker the 'dry' lights and not do anything until it shuts down (1 min.).
Ocassionally, I've also seen HO flashing during this malfunction (but not all the time I think)
Any ideas???!
