Discuss
Bosch SMU4056 Dishwasher not drying
 in
Dishwasher Repair
I have an older Bosch dishwasher and it is not drying the dishes. I performed some basic troubleshooting to try
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch SMU4056 Dishwasher not drying
  #1 (permalink)
Old 11-28-2007, 12:24 PM
Junior Member
tmsimonson is on a distinguished road
Default Bosch SMU4056 Dishwasher not drying
Model Number: SMU4056   Brand: Bosch   Age: 5 - 10 years
I have an older Bosch dishwasher and it is not drying the dishes. I performed some basic troubleshooting to try to locate the source. Here is what I have done so far.
1. I disconnected the wires from the terminals of the heating element and measured the resistance. R = 12 ohms.
2. I also measured the AC voltage being supplied to the terminals during dry mode. AC voltage = 120 VAC. This measurement was taken at the wires when disconnected from the heating element.
What is the next step. Do I need to replace the heating element or might it be something else.
Thanks in advance for any advice given on this topic.
Todd
Ads By Google
Related Models
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
Amana SNP26CB RANGE- S/I STD GAS
Amana SNP26CB0 RANGE- S/I STD GAS
Amana SNP26CB5 RANGE- S/I STD GAS
Amana SNP26ZZ RANGE- S/I STD GAS
Amana SNP26ZZ0 RANGE- S/I STD GAS
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A REF - SXS/I&W
Amana SP17A-A REF - SXS/I&W
Amana SP17A-AG REF - SXS/I&W
Amana SP17A-C REF - SXS/I&W
Amana SP17G REF - SXS/I&W
Amana SP17G-A REF - SXS/I&W
  #2 (permalink)
Old 11-29-2007, 12:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like mechanically is nothing wrong with your dishwasher.
There are two non mechanical things which could affect the drying: incoming water is too cold or there is a calcium built up inside the dishwasher.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-29-2007, 01:20 PM
Junior Member
Default
Thanks for the response. Since the inside of the dishwasher is aluminum, the calcium buildup you are referring to would have to be on the heating element itself? If so do I need to soak the heating element in CLR solution or something like that. I have physically opened up the dishwasher during the drying cycle and touched the heating element and it seemed at best lukeward to the touch.
As an experiment I placed an icecube on the heating element to see if it was warm enough to melt the ice. It only melted a little bit over 5 minutes so I concluded what heat there was there probably came from the water temperature heating up the element during wash or rinse cycle and not from the dry cycle itself.
I think as a next step I will connect a thermocouple to the heating element as well as a multimeter to the terminals of the heating element and measure cause and effect.
Thanks for your help.
Todd
  #4 (permalink)
Old 11-29-2007, 02:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The body of the dishwasher made of the stainless still, not aluminum.
If you can see a white stuff inside the dishwasher (when it's dry) this is the calcium.
The same stuff should be cover the heating element.
There is almost not possible to find the technical documentation (besides the wiring diagram) on such old dishwasher and I can not tell you what resistance should have the heating element but it should be really hot on touch.
If it's not, may be it's bad.
- The part number for the heating element AP2802201
- Here is the wiring diagram
- Here are the break down diagrams for the Bosch dishwasher Model SMU4056 US/09 (FD 7211-)
__________________
  #5 (permalink)
Old 11-29-2007, 03:08 PM
Junior Member
Default
Thank you for your help. I really appreciate it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dishwasher drying problem J Ebne Dishwasher Repair 1 12-13-2009 02:03 PM
Dishwasher not drying dstamey Dishwasher Repair 0 09-05-2009 06:19 AM
Bosch Diswasher not drying completely jillydee Dishwasher Repair 1 09-08-2008 02:53 PM
Maytag dishwasher not drying kaustin36 Dishwasher Repair 5 02-29-2008 09:21 PM
Dishwasher not drying princess Dishwasher Repair 0 01-26-2008 11:47 AM
