In the past few weeks the front door of the dishwasher has been dropping down needing me to hold it, resistance is very low (not gone but low). It used to have much more resistance where I actually had to push it down to open. I checked with a flash light both sides and i can see one spring on each side and they are both still attached, when i open the door i can see them both extending so it is not a spring issue. Is there anything else that generate opening resistance other than the springs?
