| » KitchenAid Dishwasher won't power up |
Quote:
I can't help but think you'll need the user interface, Part number: AP3085303 If the ribbon assembly is not twisted, kinked, or creased, I doubt the issue would be in the ribbon.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
That is one of the two parts that arrived today and was replaced. I get around 120v through the fuse, so I don't know what else to try. Could the replacemnt interface I got be bad? The door switch seems to work and there is power to and through the fuse. I can't figure it out. Is there a way to test the interface?
Quote:
A couple of things you'll need to check : This is a "live voltage test, so be careful. At the main control board, with the door switch bypassed or closed, Terminal P8( tan wire) to chassis ground should read 120 VAC. No voltage would indicate bad door switch or wire. Connector P2 pin 6(black / white wire) to chassis ground should read 120 VAC. No voltage would indicate a bad thermal fuse or damaged wire. At the thermal fuse the black wire to chassis ground should read 120 VAC to chassis ground. If that all checks OK, you'll need to run the diagnostic test mode : HIGH Temp(Power Scour)-Air Dry(No Heat Dry)(Energy Saver Dry)-High Temp(Power Scour)- Air Dry(No Heat Dry)(Energy Saver Dry) DIAGNOSTICS CYCLE SERVICE FEATURE – Press the above option keys in the sequence shown, while the dishwasher is inactive, to run the Diagnostics Cycle. This cycle may be rapid advanced, interval by interval, by pressing the Pots&Pans/Heavy key, Antibacteria/Cookware key, or Start key. And observe the "LED" and operation of the dishwasher. The Technical Data Sheet for your dishwasher should be attached to the backside on the lower kit plate area, If it's there you'll have a lot more information. Good Luck,
__________________
Quote:
Any part of the metal frame , bare matel, or any metal screw head, that attaches a component to the frame, will work as a good chassis grond.
__________________
that's what I figured but I wanted to be sure. I'll get back to you. Thanks for your help.
Quote:
You have a bad thermal fuse, or damaged wires. Here you go. A) The black wire to the fuse, is a direct connection back to the junction box on the frame of the dishwasher base. ( it's OK) B) The P2pin#6 wire at the control board, is attached to the outlet side of the thermal fuse, no voltage indicates a bad thermal fuse or wiring problem from the thermal fuse to the control board. C) The P8 connector on the control board, is power into the control from the door switch and the thermal fuse, no voltage indicates a wiring issue, or bad door switch and or thermal fuse. You may want to bypass the new thermal fuse, to test the dishwasher operation and wiring, but don't leave it in that condition. and then order the fuse again. Good Luck,
__________________
| Display Modes | |
| Kitchenaid Oven has power but will not heat up | ratkinso | Oven Repair (including Ranges and Cooktops) | 19 | 12-30-2012 05:30 PM |
| KitchenAid Dishewasher lost power | bmeyer8 | Dishwasher Repair | 0 | 07-19-2010 03:27 PM |
| KitchenAid Dishwasher - No Power @ Panel | Little River | Dishwasher Repair | 2 | 06-24-2010 02:19 PM |
| Kitchenaid Microwave No Power | joe-doggs | Microwave Repair | 1 | 07-17-2009 02:39 PM |
| NO POWER on 2 yr old KitchenAid Dishwasher | itssam | Dishwasher Repair | 2 | 04-10-2009 04:46 PM |
