I have a GE dishwasher mod# GSD4800G00BB. Will not turn on (no lights on front panel at all.) I opened front panel to expose the controls and timer and used a circuit tester (the kind that does not have to contact a wire)to determine that power is getting to the wires there. I need a wiring diagram to go further or suggestions as to what to check also what is the most common part to fail in there.
