Our dishwasher works great, however we have a leak in the front...facing the appliance it is in the lower right hand corner. It appears that the water is coming out from underneath where the door closes. We have replaced the seal and after searching the bottom of the door, it doesn't have any seal, just a lip that catches the water. We have raised the front of the dishwasher a couple of times and it still leaks. This is causing my floor to suffer:mad: ! Our home is 6 years old and this has been causing a problem for about 2 months. It doesn't seem to make a large spot on a towel, but enough to be aggravating. The dishwasher has been cleaned out, I use softener, and dish soap appropriate for my machine, so I hope you have some suggestions...Thank you Harold Stepp (airplane) e-mail: sandisue42@comcast.net
