Discuss
Bosch Dishwasher Soap Tray doesn't pop open
 in
Dishwasher Repair
Hi Gene, thanks for the attachment. I was wondering about how to replace the blue latch rather. I think the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Soap Tray doesn't pop open
  #11 (permalink)
Old 07-08-2010, 12:47 PM
Junior Member
froogaltexan is on a distinguished road
Default replacing 166630
Hi Gene, thanks for the attachment. I was wondering about how to replace the blue latch rather. I think the part number is 166630. Might you have instructions to replace that as well?
Now, I have never seen new parts up close so I might be wrong in my diagnosis, but when I look at the hook on the underside of the door, it doesn't look wrapped/worn out. On the other hand, the part of the latch that engages with the door doesn't look like a hook anymore so I am assuming that it's worn out. I could post pictures if you are able to tell me what to replace. Do appreciate all the help.
  #12 (permalink)
Old 07-08-2010, 04:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the dishwasher?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 07-08-2010, 07:14 PM
Junior Member
Default
It is SHU5302UC/UC12.
  #14 (permalink)
Old 07-09-2010, 06:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to check the rails on the dispenser body (where the door slides). Possible they are damaged or worn out. If this is right then the whole dispenser has to be replaced.
Here are the breakdown diagrams and Replacement parts for Bosch SHU5302 UC/12 (FD 8003-) | AppliancePartsPros.com
__________________
  #15 (permalink)
Old 08-10-2010, 08:57 PM
Junior Member
pavin is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Check the detergent actuator as described in the troubleshooting manual (page 7) from one of our previous posts: bosch dishwasher troubleshoot manual
If the reading is correct then the timer has to be replaced.
If the reading is wrong then the dispenser is bad.
I'm assuming the beginning of the model number, which is missing in your post, is "SHU" and here are the break down diagrams for the Bosch dishwasher Model SHU3032 UC/12 (FD 8003-)
- The part number for the dispenser is AP3844311
- The part number for the timer is AP2804302
Gene, thank you for all these good tips. I have a Bosch SHE43C, about 4 years old, lightly used. The dispenser door does not open during the wash cycle (have tried different cycles). The door opens and closes manually (the spring seems fine, and there doesn't seem to be any wear to the rails). I would like to conduct the tests from the troubleshooting manual, but I have no idea what testing tools are needed, how they work, or how to access the parts (I'm assuming I need to unscrew the inside door panel, but I'm not sure). I have basic mechanical and electrical competency - are there instructions that will help me figure this out, or would I be better hiring a professional?
  #16 (permalink)
Old 08-11-2010, 08:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Measure the detergent actuator resistance. It suppose to be about 2150 Ohms.
If the reading is bad, replace the actuator.
If the reading is good, replace the control module.
If you need the correct part number, post the complete model number of the dishwasher.
__________________
  #17 (permalink)
Old 01-04-2011, 05:38 AM
Junior Member
Kittykathy is on a distinguished road
Default
Gene,
I found a link to the Repair manual here: bosch dishwasher troubleshoot manual
I did check the continuity of the wax motor and it approximately 2150 ohms. I see the timer is out of stock. Is it possible to repair the timer?
Thank you.
Last edited by Kittykathy : 01-04-2011 at 06:13 AM. Reason: I found the Repair manual link
  #18 (permalink)
Old 01-06-2011, 07:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the timer is not repairable. You may want to talk to the Appliance Parts Pros team to find the ETA for this part.
__________________
  #19 (permalink)
Old 02-28-2011, 01:07 PM
Junior Member
ddmemurphy is on a distinguished road
Default
I have a Bosch dishwasher, and the soap dispenser door will not stay shut. The blue latch of the dispenser is broken....I know where to buy the part, but how do I get directions on how to replace the blue latch
  #20 (permalink)
Old 02-28-2011, 02:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to remove the outer door panel to access the soap dispenser inner parts and the soap dispenser door.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Sap Tray doesn't pop open montagequeen Dishwasher Repair 14 08-09-2013 04:39 PM
Bosch Soap Door Doesn't Open jmccs Dishwasher Repair 13 05-22-2010 09:47 AM
one on two dishwasher soap tub will not open t young Dishwasher Repair 0 11-23-2009 01:44 PM
bosch dishwasher soap tray lid tbdey Dishwasher Repair 0 03-03-2009 04:54 PM
Dishwasher soap dispenser will not open (sticks to soap) macfisto Dishwasher Repair 2 06-17-2008 08:20 AM
