Discuss
whirlpool dishwasher
 in
Dishwasher Repair
You probably have stuff stuck in the motor pump, will have to pull dishwasher to pull it off.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » whirlpool dishwasher
  #31 (permalink)
Old 07-11-2010, 05:56 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
__________________
  #32 (permalink)
Old 01-22-2011, 08:10 AM
Junior Member
Marc Center is on a distinguished road
Default Lower Wash Arm removal?
How is lower washarm removed to access the previous mentioned procedure?
  #33 (permalink)
Old 01-24-2011, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Marc,
What is the complete model number of the dishwasher?
What exactly is wrong?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #34 (permalink)
Old 01-30-2011, 01:32 PM
Junior Member
fourmasons1 is on a distinguished road
Default Can't get to the fourth screw
Quote:
Originally Posted by Gene View Post
Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8) holding by the tab on the right side.
Check the chopper (#6) for any clog.
Clean all debris and assemble in the reverse order.
Hi Gene, thanks for all th info. We got to the part where we need to remove the 4 screws, but we can't get to the 4th screw because it's underneath the water supply tube. How do you get to the 4th screw? Do you have to get the water supply tube off? We don't want to break anything. Our model number is Whirlpool Gold Quiet Partner II GU2300 XTSBO. Any help would be appreciated.
Steve
  #35 (permalink)
Old 01-30-2011, 02:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Steve,
You quoted my post but you probably did not read carefully. In the beginning it says: "...Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm..."
Here are the breakdown diagrams and Upper wash and rinse parts replacement parts for WHIRLPOOL GU2300XTSB0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
__________________
  #36 (permalink)
Old 02-16-2011, 09:02 PM
Junior Member
atx4us is on a distinguished road
Default
Quote:
Originally Posted by richappy View Post
You might have a clog going to the upper spray arm. You also may have a low water level, just dump an extra gallon in to see if it works
My Kenmore model # 665.13482K901 dishwasher was hardly even wetting the dishes. At the beginning of every new wash cycle, it would fill with water, then run for about 10 seconds, stops and fills with more water and then starts again. But, it still isn't enough water. I tried adding extra water with a bucket as suggested here and the dishwasher is spraying all the dishes as it should be.
How can I set the correct amount of fill water in this dishwasher? Thanks.
  #37 (permalink)
Old 02-17-2011, 01:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by atx4us View Post
...I tried adding extra water with a bucket as suggested here and the dishwasher is spraying all the dishes as it should be.
Sounds like the problem is a bad water inlet valve. You can try to clean the screen inside it but the best solution is to replace it.
- The water inlet valve AP4433986
__________________
  #38 (permalink)
Old 02-21-2011, 09:58 AM
Junior Member
ljfreeze@optonline.net is on a distinguished road
Default why does chopper clog on a weekly basis
I have a whirlpool GU2400xtps1 and the chooper get filled with debris on a weekly basis. When i clean the chopper the dishwasher cleans well for a week. What could cause the chooper to get clogged so frequently?
  #39 (permalink)
Old 02-21-2011, 02:55 PM
Senior Expert
APP Volunteer
Default
Try to turn the chopper, if it turns freely, it's bad, must turn with the motor impeller.
__________________
  #40 (permalink)
Old 02-21-2011, 03:20 PM
Junior Member
Default Clogged chopper
The chopper is new. Only the outside metal wings? spin. I'm thinking it may be the check valve but why would the check valve fail. I've read that there is something that is supposed to flush the chopper. Maybe it is not being flushed properly?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher rcmleong Dishwasher Repair 1 01-27-2010 03:42 AM
whirlpool dishwasher wudz Dishwasher Repair 0 09-03-2008 04:28 PM
whirlpool dishwasher andyo Dishwasher Repair 0 09-01-2008 11:30 AM
Whirlpool Dishwasher Jon Ziarko Dishwasher Repair 1 08-09-2007 04:54 PM
