Discuss
whirlpool dishwasher
 in
Dishwasher Repair
Originally Posted by richappy What was the original problem, no water pressure? If so, you might have a pump motor
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » whirlpool dishwasher
  #21 (permalink)
Old 04-13-2009, 03:37 PM
BrianT267 BrianT267 is offline
Junior Member
BrianT267 is on a distinguished road
Default
Quote:
Originally Posted by richappy View Post
What was the original problem, no water pressure? If so, you might have a pump motor running backwards!
Thanks for the reply. The original problem (and current) is the dishwasher fills up but the does not start the cycle it just shuts off.
So I followed the procedure in this thread to clean out the Chopper. I did not take the pump motor out, looks like the chopper only fits one way. I inspected the check valve and it looked ok so I put it back. Could the rubber be fatigued even tough it looks good?
any advice on what to check next would be appreciated.
  #22 (permalink)
Old 04-14-2009, 02:43 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would pull the dishwasher and check the main pump/motor. THis is a 115 volt motor you can power up with a "cheater" cord. If you have a meter you can check for missing power at various places.
__________________
  #23 (permalink)
Old 04-14-2009, 08:02 PM
Junior Member
Default
Thanks I will give that a try.
  #24 (permalink)
Old 06-29-2009, 02:08 PM
srhgobears srhgobears is offline
Junior Member
srhgobears is on a distinguished road
Default
Slightly off topic - I'm having a problem (apparently) with the sump-pump gasket - our dishwasher has been leaking from underneath. I had a Kitchenaid/Whirlpool repair guy come out and stated he was 100% confident that the sump pump gasket was the culprit but it would be $300 in labor to repair and only a $20 part.
It sounds like the whole dishwasher needs to be unhooked (unfortunately the electrical was hard-wired into the dishwasher by the previous owner of our house), and the whole sump pump removed. Before I do this I wanted to check with the experts here on the viability of a novice do-it-yourselfer going at it. Here's the part I think I need: WHIRLPOOL Gasket, Pump sump
Input would be great.
  #25 (permalink)
Old 06-29-2009, 09:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
You can find the complete instructions in the tech sheets.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI01ILBL2 | AppliancePartsPros.com
__________________
  #26 (permalink)
Old 08-08-2009, 01:24 PM
chiefa chiefa is offline
Junior Member
chiefa is on a distinguished road
Default Kenmore 665.17464300 not claening top rack
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
How can I check to make sure the chopper is engaging the motor impeller? The chopper blade seems to turn quite easily. I am wondering if this is what is causing the reduced water pressure so that the top rack in not getting cleaned.
  #27 (permalink)
Old 08-08-2009, 04:24 PM
Senior Expert
APP Volunteer
Default
You have a busted chopper, just pull out and check.
__________________
  #28 (permalink)
Old 08-20-2009, 06:03 PM
Junior Member
Default
I pulled the chopper assembly, compared to a new one and it does not appear to be broken in any way. It also does engage the impeller when it is in place. Should I be testing the motor next? If so, I am not sure how to do that. Can you help?
  #29 (permalink)
Old 08-21-2009, 03:00 AM
Senior Expert
APP Volunteer
Default
You might have a clog going to the upper spray arm. You also may have a low water level, just dump an extra gallon in to see if it works
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher malfunction rick Dishwasher Repair 2 03-03-2009 09:14 AM
Whirlpool Dishwasher mhjackson@bellsouth.net Washer Repair 1 11-23-2007 01:55 PM
Whirlpool dishwasher does not drain Sdj Dishwasher Repair 6 10-09-2007 11:32 AM
Dishwasher - Whirlpool mhedges168 Dishwasher Repair 1 09-05-2007 12:21 AM
Whirlpool Dishwasher Jon Ziarko Dishwasher Repair 1 08-09-2007 05:54 PM
