Discuss
whirlpool dishwasher
 in
Dishwasher Repair
[quote=Gene;8058]Remove the upper dish rack. Remove the water feeding tube for the upper spray arm. Remove 4
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » whirlpool dishwasher
  #11 (permalink)
Old 12-26-2007, 11:34 PM
DavidN6DF DavidN6DF is offline
Junior Member
DavidN6DF is on a distinguished road
Exclamation my top cover screws are not the slotted type shown
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8 on the break down diagram) holding by the tab on the right side.
Clean all debris and assemble in the reverse order.
the screws for the cover on my Whirlpool GU2500 sre not the slotted type shown in the diagram but some sort of hex type. I couldn't find an allen wrench to fit. Any idea what type of tool is needed?
  #12 (permalink)
Old 12-27-2007, 03:34 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You will need to buy a set of torx bits for these.
__________________
  #13 (permalink)
Old 12-27-2007, 05:46 PM
Junior Member
Default thanks
Thanks for the suggestion about torx bits!
  #14 (permalink)
Old 03-14-2009, 08:11 AM
jlp7534 jlp7534 is offline
Junior Member
jlp7534 is on a distinguished road
Default
I have a Kenmore model 66517514200 and I think the Chopper is the problem. However, I can't get the inlet protector off to get to the chopper. I removed 2 screws and can't see any others. It will not budge and I don't want to damage the part trying.
Can someone help with this? Thanks.
  #15 (permalink)
Old 03-14-2009, 02:41 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
Rotate the screw-end of the protector upward to remove the part and expose the chopper assembly.
__________________
  #16 (permalink)
Old 03-14-2009, 04:17 PM
Senior Expert
APP Volunteer
Default
I use a flat bladed screw driver to pry on the right side of the half round chopper housing, eventually it will work loose. Usually a build up of soap residue makes it stick. If the chopper screen is clogged, you will need a new chopper and check valve in the bottom of the housing.
__________________
  #17 (permalink)
Old 04-13-2009, 12:58 PM
BrianT267 BrianT267 is offline
Junior Member
BrianT267 is on a distinguished road
Default
Quote:
Originally Posted by richappy View Post
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
Hello all I was following this procedure and found a part 8268297 it is a small white plastic coneshapped item. I'm not sure where it came from I was wiping out the bottom and found it. I think it may have fell from the top where the upper water feed is. Help! I don't want to put back together with extra parts.
thanks
  #18 (permalink)
Old 04-13-2009, 01:15 PM
Junior Member
Default
Quote:
thanks
Never mind i found it it does go in the upper water feed i think it is a nozzle. Putting the chopper back in and getting it to engage the impeller is a bear.
  #19 (permalink)
Old 04-13-2009, 01:54 PM
Junior Member
Default
I put it back together and it still does not work. What is the next step? the chopper had scum on it but turned as did the impeller. The check valve looked ok it was intact I don't know if the rubber gets stretched out over time. Should those to things be replaced or is there something else to look at?
  #20 (permalink)
Old 04-13-2009, 02:17 PM
Senior Expert
APP Volunteer
Default
What was the original problem, no water pressure? If so, you might have a pump motor running backwards!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher malfunction rick Dishwasher Repair 2 03-03-2009 09:14 AM
Whirlpool Dishwasher mhjackson@bellsouth.net Washer Repair 1 11-23-2007 01:55 PM
Whirlpool dishwasher does not drain Sdj Dishwasher Repair 6 10-09-2007 11:32 AM
Dishwasher - Whirlpool mhedges168 Dishwasher Repair 1 09-05-2007 12:21 AM
Whirlpool Dishwasher Jon Ziarko Dishwasher Repair 1 08-09-2007 05:54 PM
