justinpickard81
#1 Posted : Wednesday, August 24, 2011 1:29:40 PM(UTC)
justinpickard81
Where does the power to my dishwasher most likely come from? It is not plugged into an outlet. The nearest outlet is where the Garbage disposal is plugged in. The dishwasher power cable appears to be heading that way. Would the power be tapped from that outlet?
I can't flip the breaker because I don't know which one it is and I cant use trial and error because the dishwasher doesn't turn on anyway...
magician59
#2 Posted : Wednesday, August 24, 2011 1:50:01 PM(UTC)
magician59
It's supposed to be hard-wired to its own 20 Amp circuit breaker. Whether it is or not depends on who installed it.
If you are handy with a meter, you can spot the right breaker by opening the electrical box under the dishwasher. You don't necessarily have to disconnect anything (I don't recommend it anyway!). Just insert a probe of the meter (Make sure it's set to the 200VAC range) into the wire-nut (cap) with the black wire; and the other into the white connector.
If you get a reading (I usually get someone to help by flipping breakers off until the right one is found), turn off the appropriate breaker, and mark its number with a permanent marker, on the cover plate.
If you don't get a reading for voltage, go to the breaker box and look for a tripped breaker. It won't be flipped all the way to the off position, but its position will be easy to spot, compared with the others.
Oven door locked, no power? (Oven Repair (including Ranges and Cooktops))
by reckless67 10/27/2013 1:50:44 PM(UTC)
Whirlpool dishwasher no power? (Dishwasher Repair)
by dsills 9/17/2013 7:55:42 AM(UTC)
Kenmore Dishwasher no power? (Dishwasher Repair)
by oilhammer 3/16/2012 9:14:33 AM(UTC)
Will fuse removal cut power? (Microwave Repair)
by lfranksathome 3/5/2012 10:49:47 AM(UTC)
Does it run on 110 or 220 power? (Heating, Ventilation, and Air Conditioning (HVAC))
by Mary Anderson 7/24/2011 3:44:42 PM(UTC)
Kenmore dryer - no power?? (Dryer Repair)
by Greyfus 9/29/2010 9:18:15 AM(UTC)
No lights on font panel-nopower?? (Dishwasher Repair)
by finman 2/8/2010 6:10:41 AM(UTC)
Kenmore Elite He4 Dryer NO POWER? (Dryer Repair)
by BerkelUSA 6/14/2009 8:58:36 AM(UTC)
How does one connect an electric oven to power? (Oven Repair (including Ranges and Cooktops))
by Bill Keefe 4/22/2009 7:55:34 AM(UTC)
Ice & water dispenser - no power? (Refrigerator & Freezer Repair)
by PatM 3/13/2008 3:49:32 PM(UTC)
Fan won't stop cycling. kill the power? (Oven Repair (including Ranges and Cooktops))
by Jo a 12/20/2007 5:19:47 AM(UTC)
