Hello, A few months after I purchased this dishwasher the start button began to work intermittently until it finally stopped working completely. I just replaced the control module with Part Number 154712101 and now the cycle starts up and all the lights turn on but it does not run through each cycle. The dishwasher starts its first cycle and adds water but then stops doing anything until 15 mins later when it drains the water and starts over again. Any recommendations? Thanks! Daniel
The serial to this dishwasher is TH64295860 The serial to the original control module is SF2401-K8401-C Rev M
