Discuss
Dishwasher help
 in
Dishwasher Repair
Dishwasher will fill. Once it is filled it won't start to wash on any cycles or on the rinse
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher help
  #1 (permalink)
Old 11-26-2007, 02:56 PM
beerstud beerstud is offline
Junior Member
beerstud is on a distinguished road
Default Dishwasher help
Model Number: DU1048XTPQ4   Brand: Whirlpool   Age: 1 - 5 years
Dishwasher will fill. Once it is filled it won't start to wash on any cycles or on the rinse cycle. After it fills I can hear a click and then nothing, and on occasion after the click I can hear a hum. I have made sure the float is not jammed and moves freely, and if I hit the cancel/drain it will drain OK. Any help?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-26-2007, 04:05 PM
alexchaumont alexchaumont is offline
Junior Member
alexchaumont is on a distinguished road
Default
I am not a repairman but I had the exact same thing happen to me with a Whirlpool dishwasher that is 4 years old. Water would fill the base, clicking sound, then humming, but no washing, hit the 'Cancel' button and the water would drain out.
Your pump motor is out. There are instructions on how to check this attached to the back of the metal facing at the base of the dishwasher. Unscrew the 2 screws holding the facing and on the back of it there is a diagnostics sheet. This will tell you how to check the pump without having to remove the entire dishwasher.
The pump motor will run you around $130.00 online. The instructions to replace it are with that diagnostics sheet attached to your dishwasher. If you do not have that sheet you will have to search online how to replace it. I have very little do-it-yourself experience and I was able to follow the instructions and replace the pump motor. It is an involved process, however, which will require taking the dishwasher out from under your counter, turning it on its side, and getting water everywhere. If you are prepared to deal with that you can do it yourself and save a couple hundred bucks.
But a brand new dishwasher is only $400, so that decision is up to you! Hope this helps!
  #3 (permalink)
Old 11-29-2007, 12:52 PM
bikrmikey bikrmikey is offline
Junior Member
bikrmikey is on a distinguished road
Default
I have the same problem, replaced the motor problem still persisits. When the machine drains it requires the pump so it seems to be a control panel issue. Anyone else?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
