mammal40
#1 Posted : Sunday, August 21, 2011 7:00:37 AM(UTC)
mammal40
My dishwasher was sporadically not filling. Now it will not fill. I checked a couple of things and have found the following:
106 volts at the water valve when it's supposed to be operating.
18 volts at the float when the switch is closed.
106 volts between the water valve and float.
I have verified 120 volts to the machine so the voltages I measured seem odd. Any help would be greatly appreciated.
J2H
#2 Posted : Saturday, August 24, 2013 2:18:36 PM(UTC)
J2H
The voltage across the float switch should be 0 with 120 across the valve when the valve is open - 18 volts means you've got bad contacts in the switch and it should be replaced.
Maytag won't fill mvwc565fw1 (Washer Repair)
by TitoSant259 3/14/2023 7:46:09 AM(UTC)
Maytag won't fill. Valve or Control panel? (Dishwasher Repair)
by tdfaber 10/1/2011 1:21:37 PM(UTC)
Maytag won't fill (Washer Repair)
by NJB 8/22/2011 5:16:51 AM(UTC)
by emberpatch 6/3/2011 10:24:18 PM(UTC)
