when I wash dishes the soap in the soap cup does not dissolve completely I am using a rinse aid and I am using Finsh tabs which already have a rinse aid in them. what happens is part of the tab, the plastic outer cover is not dissolving and the red dot stays in the soap cup along with some of the soap.
Originally Posted by: SPACECAT99 when I wash dishes the soap in the soap cup does not dissolve completely
I am using a rinse aid and I am using Finsh tabs which already have a rinse aid in them. what happens is part of the tab, the plastic outer cover is not dissolving and the red dot stays in the soap cup along with some of the soap. :confused:
