Dishwasher Leaking
Dishwasher Repair
After a wash cycle they soapy water is discharged and it is free-flowing down the lower front of the machine
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Leaking
  #1 (permalink)
Old 04-01-2009, 02:54 PM
Junior Member
rosygt is on a distinguished road
Default Dishwasher Leaking
Model Number: FDB2810DS0   Brand: Frigidaire   Age: 1 - 5 years
After a wash cycle they soapy water is discharged and it is free-flowing down the lower front of the machine right next to where the wire harness enters the base of the machine. It does this after the clean cycle and then the rinse cycle.
Related Models
Frigidaire FDB2810LDB0 Frigidaire/dishwshaer
Frigidaire FDB2810LDC0 Frigidaire/dishwshaer
Frigidaire FDB2810LDC1 Frigidaire/dishwasher
Frigidaire FDB2810LDC2 Frigidaire/dishwasher
Frigidaire FDB2810LDQ0 Frigidaire/dishwshaer
Frigidaire FDB2810LDS0 Frigidaire/dishwshaer
Frigidaire FDB2830CEB0 Frigidaire/dishwasher
Frigidaire FDB2830CEB1 Frigidaire Canada/dishwasher
Frigidaire FDB2830CEB2 Frigidaire Canada/dishwasher
Frigidaire FDB2830CEC0 Frigidaire/dishwasher
Frigidaire FDB2830CEC1 Frigidaire Canada/dishwasher
Frigidaire FDB2830CEC2 Frigidaire Canada/dishwasher
Frigidaire FDB2830CES0 Frigidaire/dishwasher
Frigidaire FDB2830CES1 Frigidaire Canada/dishwasher
Frigidaire FDB2830CES2 Frigidaire Canada/dishwasher
Frigidaire FDB30R1 Frigidaire/dehumidifier
Frigidaire FDB345CHS0 Dishwasher
Frigidaire FDB345LBB0 Frigidaire/dishwasher
Frigidaire FDB345LBB1 Frigidaire/dishwasher
Frigidaire FDB345LBS0 Frigidaire/dishwasher
Frigidaire FDB345LBS1 Frigidaire/dishwasher
Frigidaire FDB345LFR0 Dishwasher
Frigidaire FDB345LFR1 Frg/dishwasher
Frigidaire FDB345LFR2 Frigidaire/dishwasher
Frigidaire FDB345LFS0 Dishwasher
Frigidaire FDB345LFS1 Frg/dishwasher
Frigidaire FDB345LFS2 Frigidaire/dishwasher
Frigidaire FDB421RFR0 Frg(v1) / Built - in Dishwasher
Frigidaire FDB421RFR1 Frg(v1) / Built - in Dishwasher
Frigidaire FDB421RFR2 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire FDB421RFR3 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire FDB421RFR4 Dishwasher
Frigidaire FDB421RFR5 Frg(v1) / Dishwasher
Frigidaire FDB421RFR6 Frigidaire/dishwasher
Frigidaire FDB421RFR7 Frigidaire/dishwasher
Frigidaire FDB421RFS0 Frg(v2) / Built - in Dishwasher
Frigidaire FDB421RFS1 Frg(v2) / Built - in Dishwasher
Frigidaire FDB421RFS2 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire FDB421RFS3 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire FDB421RFS4 Dishwasher
Frigidaire FDB421RFS5 Frg(v2) / Dishwasher
Frigidaire FDB421RFS6 Frigidaire/dishwasher
Frigidaire FDB421RFS7 Frigidaire/dishwasher
Frigidaire FDB421RFS8 Frigidaire/dishwasher
Frigidaire FDB4315LFB0 Frigidaire/dishwasher
Frigidaire FDB4315LFC0 Frigidaire/dishwasher
Frigidaire FDB4315LFS0 Frigidaire/dishwasher
Frigidaire FDB435RFR0 Frg(v0) / Built - in Dishwasher
Frigidaire FDB435RFR1 Frg(v0) / Built - in Dishwasher
Frigidaire FDB435RFR2 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire FDB435RFR3 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire FDB435RFR4 Frg(v0)
Frigidaire FDB435RFR5 Frg/dishwasher
Frigidaire FDB435RFR6 Frigidaire/dishwasher
Frigidaire FDB435RFR7 Frigidaire/dishwasher
Frigidaire FDB435RFS0 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire FDB435RFS2 Dishwasher
Frigidaire FDB435RFS3 Frg/dishwasher
Frigidaire FDB435RFS4 Frigidaire/dishwasher
Frigidaire FDB435RFS5 Frigidaire/dishwasher
Frigidaire FDB50R1 Frigidaire/dehumidifier
Frigidaire FDB510CFB0 Frigidaire Canada/dishwasher
Frigidaire FDB510CFB1 Frigidaire Canada/dishwasher
Frigidaire FDB510CFB2 Frigidaire Canada/dishwasher
Frigidaire FDB510CFS0 Frigidaire Canada/dishwasher
Frigidaire FDB510CFS1 Frigidaire Canada/dishwasher
Frigidaire FDB510CFS2 Frigidaire Canada/dishwasher
Frigidaire FDB510CGC0 Frigidaire Canada/dishwasher
Frigidaire FDB510LCB0 Frigidaire/dishwasher
Frigidaire FDB510LCB1 Frigidaire/dishwasher
Frigidaire FDB510LCB2 Frigidaire/dishwasher
Frigidaire FDB510LCB3 Frigidaire/dishwasher
Frigidaire FDB510LCS0 Frigidaire/dishwasher
Frigidaire FDB510LCS1 Frigidaire/dishwasher
Frigidaire FDB510LCS2 Frigidaire/dishwasher
Frigidaire FDB510LCS3 Frigidaire/dishwasher
Frigidaire FDB632RBD0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire FDB632RBS0 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire FDB634CFS0 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire FDB634CFS2 Dishwasher
Frigidaire FDB634CFS3 Frigidaire/dishwasher
Frigidaire FDB634CFS4 Frigidaire/dishwasher
Frigidaire FDB635RBB0 Frigidaire/dishwasher
Frigidaire FDB635RBB1 Frigidaire/dishwasher
Frigidaire FDB635RBQ0 Frigidaire/dishwasher
Frigidaire FDB635RBQ1 Frigidaire/dishwasher
Frigidaire FDB635RBS0 Frigidaire/dishwasher
Frigidaire FDB635RBS1 Frigidaire/dishwasher
Frigidaire FDB635RFR0 Frg(v1) / Built - in Dishwasher
Frigidaire FDB635RFR1 Frg(v1) / Built - in Dishwasher
  #2 (permalink)
Old 04-01-2009, 06:21 PM
Senior Member
applianceman is on a distinguished road
This sounds like a soap problem, either a small amount of non-dishwasher detergent has accidentally entered the washer or your using one of those 3-in-1 action packs. If you are using the 3-in-1 action pack stop and see if the leak goes away because I have seen this kind of soap cause dishwashers to leak a lot. Dishwasher Leaking Repair Guide
  #3 (permalink)
Old 04-02-2009, 01:58 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
You can dump in a gallon of vineger to remove the soap and foam.
  #4 (permalink)
Old 04-02-2009, 05:30 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Here is the parts breakdown
Model Search
Open the unit up half way through a wash cycle
Check for suds. A little bit of froth is normal but if you have suds then it is a soap problem.
Check that all the holes in the spray arm are clear. Sometimes you can get a partial plug and it will spray at a weird angle and cause a leak.
Check that the filter on the tub floor is laying flat. Again sometimes it can redirect the water and cause a leak.
Check that the water is actually leaking out of the tub or is it leaking out of the door's outside panel
Check #49 in the Door section of the above parts breakdown.
See the following at TechnicianBrian's website
Model Search
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Dishwasher macnlrc Dishwasher Repair 1 11-10-2009 02:51 AM
GE Dishwasher leaking _Joe_ Dishwasher Repair 4 08-06-2009 04:43 PM
GE Dishwasher Leaking leland48 Dishwasher Repair 2 04-15-2009 12:31 PM
GE dishwasher leaking Chuck Hamby Dishwasher Repair 1 11-09-2008 12:48 PM
Dishwasher leaking jeremiah Dishwasher Repair 3 11-14-2007 11:02 AM
