Discuss
flapper check valve & beading for spray arm low
 in
Dishwasher Repair
I removed the lower spray arm to get to the filter to see if it was clogged...and two small
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » flapper check valve & beading for spray arm low
  #1 (permalink)
Old 11-24-2007, 01:35 PM
laineyo laineyo is offline
Junior Member
laineyo is on a distinguished road
Question flapper check valve & beading for spray arm low
Model Number: GSD6200G00BB   Brand: GE   Age: 1 - 5 years
I removed the lower spray arm to get to the filter to see if it was clogged...and two small round parts came out but I can't tell how they go back... I've identified them as: 1) Flapper check valve Part Number: AP3669275 made by GE and 2) bearing spray arm low Part Number: AP3669207 made by GE.
The flapper check valve is copper and stamped "REVERWARE". I can't tell if it goes down in to the main conduit where water sprays up from and if so, does it go REVERWARE side up or down? It may go on the conduit tube - there's another hole there (just behind the main conduit that the spray arm sits in to) that looks like it would fit but again, not sure if Reverware side up or down. The bearing is a silver round ring and I am pretty sure that goes in to the main conduit and then the spray arm just rests on top of it but need confirmation and if the flapper goes there too, which goes in first?
I've called 3 appliance repair services and haven't even gotten a call back and am running out of dishes!
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-25-2007, 08:21 AM
Junior Member
Smile Nevermind....
Nevermind, I figured it out. The Revereware part was from a pair of kitchen shears washed long ago..... all is working fine thanks to the diagrams on this website.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Check Washer Motor & Capacitor mickey11 Washer Repair 2 06-15-2008 10:09 AM
To check defrost heater don419 Refrigerator & Freezer Repair 2 02-26-2008 09:51 PM
how to check thermo fuse and thermostat lilphil Dryer Repair 0 11-20-2007 08:43 AM
How can I check the relay and/or cap frepair Refrigerator & Freezer Repair 1 10-18-2007 08:37 PM
Spray arm romeroom Dishwasher Repair 2 09-08-2007 01:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
