| » KitchenAid Long wash cycle |
Model Number: KUD 1021 RBL3
Checked temperature of hot water supply to dishwasher and it measured 120-125F. Turned on hot water at sink in order to get hot water into the system before starting dishwasher.
Selected Normal wash cycle without the dry option. Took 110 min to complete washing. What's up? FSP Thermostat 661566 and sensor W10134017 have been replaced. Ads By Google Related Models |
Here is a tech sheet
https://www.servicematters.com/docs/...0W10130990.pdf You may not have a problem. Tech shows Normal with heated dry is 105 minutes. Not sure but usually the only difference between heated and non-heated is that the heater is not turned on, timer still runs through the heat time. Try a cycle with heated dry. Open it when in the heated dry part of the cycle, check the heater. Be careful to not burn your fingers!!!
__________________
| Display Modes | |
| Bosch dishwasher long wash period | richappy | Dishwasher Repair | 1 | 04-06-2012 11:05 AM |
| When wash is complete the machine stay on agitate and won't allow a new wash cycle | Trofytrout | Washer Repair | 1 | 07-07-2009 01:34 PM |
| kitchenaid long cycle | mazda | Dishwasher Repair | 3 | 04-28-2009 02:40 AM |
| Long Wash Cycle (5+ hours) | smackay13 | Dishwasher Repair | 3 | 12-18-2008 09:57 PM |
| How long should the wash cycle last? | tthomas0078 | Dishwasher Repair | 2 | 12-08-2008 07:17 AM |
