Discuss
GE Profile Dishwasher
 in
Dishwasher Repair
My dishwasher is 2 1/2 years old and it quit pumping water into the dishwasher. You can hear the dishwasher
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Profile Dishwasher
  #1 (permalink)
Old 03-28-2009, 07:57 AM
Junior Member
neeley3737 is on a distinguished road
Default GE Profile Dishwasher
Brand: GE   Age: 1 - 5 years
My dishwasher is 2 1/2 years old and it quit pumping water into the dishwasher. You can hear the dishwasher pump, but there is no water coming in the basin.
Ads By Google
  #2 (permalink)
Old 03-28-2009, 08:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A Model Number might help others help you.
The unit does not pump water in. It simply opens a valve.
Remove the kick plate.
Valve is usually on the left hand side.
Remove the wires from the valve and measure it for continuity use a 2 Kohm scale.
If it is an open (infinite ohms) then it is shot.
If OK.
Check the over fill switch, also on the left hand side.
Float may be stuck in the up position.
The switch should be closed (0 ohms).
If OK
Reconnect the float switch
Place the timer at the start of a cycle (fill)
Measure for volts across the valves wires, should get 120 volts with door closed
If no voltage then the timer may be shot.
If OK
Either the valve is shot or the filter screen on it's input side is clogged with gunk.
Shut the water supply off.
Remove the valve and check/clean the screen.
Do not remove the screen. It is there to keep crud out of the valve which might hold the valve open and cause a flood.
If screen is clean probably the valve is shot
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Dishwasher spongebob9936 Dishwasher Repair 0 08-11-2009 03:07 PM
GE Profile Dishwasher dilagaf Dishwasher Repair 1 05-30-2009 02:57 PM
GE Profile Dishwasher vmac Dishwasher Repair 0 07-29-2008 03:28 PM
GE Profile Dishwasher Tim1539 Dishwasher Repair 9 04-02-2008 06:40 PM
ge profile dishwasher barbariano298 Dishwasher Repair 1 01-25-2008 10:31 AM
