Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   dishwasher completely shut down (http://forum.appliancepartspros.com/dishwasher-repair/277813-dishwasher-completely-shut-down.html)
florida1 08-05-2011 06:14 AM
the unit shut down during last cycle before completely finishing. none of the lights on the panel come on, i check breaker and it was not tripped. I am reading it may be the thermal fuse? or could it be something else. I replaced the panel about 6-8 months ago. Thanks.
Joe / APP Team 08-05-2011 07:36 AM
Quote:
Florida,
You're on the right track, If the unit is dead, you do want to start at the thermal fuse and door switches up in the control panel.
Part number: AP3178588
Part number: AP3039128
The thermal fuse should have a constant "closed" circuit, and the door switch circuit will open then close, when the switch plunger is pressed and released, when checking with a multi meter.
Good Luck,
http://forum.appliancepartspros.com/...-ohmmeter.html
