Discuss
Dishwasher repair
 in
Dishwasher Repair
We woke to find that the washer had not run, did diagnostic ended up replacing control board and fuse. Still
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher repair
  #1 (permalink)
Old 03-27-2009, 10:19 AM
Junior Member
kilothirty is on a distinguished road
Default Dishwasher repair
Model Number: DUL300XTKT0   Brand: Whirlpool   Age: 1 - 5 years
We woke to find that the washer had not run, did diagnostic ended up replacing control board and fuse. Still won't turn on, high temp scour flashes, run test and normal light flashes also. Don't know what's up.
Related Models
Whirlpool DUL300XTKT0 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLB1 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLB2 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLB3 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLQ2 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLQ3 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLS0 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLS1 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLS2 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLT0 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLT1 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLT2 UNDERCOUNTER DISHWASHER
Whirlpool DUL300XTLT3 UNDERCOUNTER DISHWASHER
 DUORSRKIT ELECTROLUX/TRIM KIT
Amana DUP202-19OR DISHWASHER- UNDERCOUNTER
Amana DUP204-19OR DISHWASHER- UNDERCOUNTER
Amana DUP206-19OR DISHWASHER- UNDERCOUNTER
Amana DUR20219OK DISHWASHER- UNDERCOUNTER
Amana DUR2021WOL DISHWASHER- UNDERCOUNTER
Amana DUR20319-CL DISHWASHER- UNDERCOUNTER
Amana DUR20319-OS DISHWASHER- UNDERCOUNTER
Amana DUR20319CK DISHWASHER- UNDERCOUNTER
Amana DUR20319CL DISHWASHER- UNDERCOUNTER
Amana DUR20319OK DISHWASHER- UNDERCOUNTER
Amana DUR20319OL DISHWASHER- UNDERCOUNTER
Amana DUR20419-OS DISHWASHER- UNDERCOUNTER
Amana DUR20419CK DISHWASHER- UNDERCOUNTER
Amana DUR20419CL DISHWASHER- UNDERCOUNTER
Amana DUR20419OK DISHWASHER- UNDERCOUNTER
Amana DUR20419OL DISHWASHER- UNDERCOUNTER
Amana DUR20519-OS DISHWASHER- UNDERCOUNTER
Amana DUR20519CK DISHWASHER- UNDERCOUNTER
Amana DUR20519OK DISHWASHER- UNDERCOUNTER
Amana DUR20519OL DISHWASHER- UNDERCOUNTER
Amana DUR20819-OS DISHWASHER- UNDERCOUNTER
Amana DUR20819CK DISHWASHER- UNDERCOUNTER
Amana DUR20819CL DISHWASHER- UNDERCOUNTER
Amana DUR20819OK DISHWASHER- UNDERCOUNTER
Amana DUR20819OL DISHWASHER- UNDERCOUNTER
Amana DUS-114-19 DISHWASHER- UNDERCOUNTER
Amana DUS-202-1W DISHWASHER- UNDERCOUNTER
Amana DUS-203-19 DISHWASHER- UNDERCOUNTER
Amana DUS-204-19 DISHWASHER- UNDERCOUNTER
Amana DUS-205-19 DISHWASHER- UNDERCOUNTER
Amana DUS-208-19 DISHWASHER- UNDERCOUNTER
Amana DUS-401-19 DISHWASHER- UNDERCOUNTER
Amana DUS-401-1W DISHWASHER- UNDERCOUNTER
Amana DUS-402-19 DISHWASHER- UNDERCOUNTER
Amana DUS-404-19 DISHWASHER- UNDERCOUNTER
Amana DUS-405-19 DISHWASHER- UNDERCOUNTER
Amana DUS-406-19 DISHWASHER- UNDERCOUNTER
Amana DUS-407-19 DISHWASHER- UNDERCOUNTER
Amana DUS-409-19 DISHWASHER- UNDERCOUNTER
Amana DUS-416-1W DISHWASHER- UNDERCOUNTER
Amana DUS104-19 DISHWASHER- UNDERCOUNTER
 DUS200W DISHWASHER- UNDERCOUNTER
Amana DUS202-1A DISHWASHER- UNDERCOUNTER
Amana DUS202-1C DISHWASHER- UNDERCOUNTER
Amana DUS202-1H DISHWASHER- UNDERCOUNTER
Amana DUS202-1L DISHWASHER- UNDERCOUNTER
Amana DUS202-1W DISHWASHER- UNDERCOUNTER
Amana DUS2021W-0A DISHWASHER- UNDERCOUNTER
Amana DUS203-19 DISHWASHER- UNDERCOUNTER
Amana DUS20319-OA DISHWASHER- UNDERCOUNTER
Amana DUS204-19 DISHWASHER- UNDERCOUNTER
Amana DUS20419-OA DISHWASHER- UNDERCOUNTER
Amana DUS205-19 DISHWASHER- UNDERCOUNTER
Amana DUS20519-OA DISHWASHER- UNDERCOUNTER
Amana DUS20719-OA DISHWASHER- UNDERCOUNTER
Amana DUS208-19 DISHWASHER- UNDERCOUNTER
Amana DUS20819-OA DISHWASHER- UNDERCOUNTER
Amana DUS300B DISHWASHER- UNDERCOUNTER
Amana DUS300L DISHWASHER- UNDERCOUNTER
Amana DUS31419 DISHWASHER- UNDERCOUNTER
Amana DUS400B DISHWASHER- UNDERCOUNTER
Amana DUS500B DISHWASHER- UNDERCOUNTER
Amana DUS600B DISHWASHER- UNDERCOUNTER
Amana DUS600B,WW DISHWASHER- UNDERCOUNTER
Amana DUS600WW DISHWASHER- UNDERCOUNTER
Amana DUS900B DISHWASHER- UNDERCOUNTER
 DV306LEW DRYER- ELE
 DV306LEW/XAA DRYER- ELE
 DV306LGW DRYER- GAS
 DV306LGW/XAA DRYER- GAS
 DV316BEC DRYER- ELE
 DV316BEC/XAA DRYER- ELE
 DV316BEW DRYER- ELE
 DV316BEW/XAA DRYER- ELE
 DV316BGC DRYER- GAS
 DV316BGC/XAA DRYER- GAS
 DV316BGW DRYER- GAS
 DV316BGW/XAA DRYER- GAS
 DV316LES DRYER- ELE
 DV316LES/XAA DRYER- ELE
 DV316LEW DRYER- ELE
 DV316LEW/XAA DRYER- ELE
 DV3C6BEW DRYER- ELE
 DV3C6BEW/XAA DRYER- ELE
 DV3C6BGW DRYER- GAS
 DV3C6BGW/XAA DRYER- GAS
Dynasty DVH30 HOOD
Dynasty DVH36 HOOD
Dynasty DVH42 HOOD
Dynasty DVH48 HOOD
  #2 (permalink)
Old 03-28-2009, 02:36 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL DUL300XTKT0 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/...%208533399.pdf
You may have a stuck key, the tech sheet has a test procedure.
Also check that the keaypad connectors are OK
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
__________________
  #3 (permalink)
Old 03-28-2009, 07:51 AM
Junior Member
Default
Thanks! I will try that. Was trying to avoid a service call, but may pay more in the long run possibly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Repair myracosta Dishwasher Repair 0 02-06-2010 09:23 PM
Dishwasher repair rhreed19 Dishwasher Repair 0 09-08-2009 12:53 PM
dishwasher repair cjrimer Dishwasher Repair 3 08-14-2009 07:50 AM
Dishwasher Repair bweldon4852@yahoo.co Dishwasher Repair 0 06-16-2009 12:13 PM
Dishwasher repair blk Dishwasher Repair 0 12-26-2008 06:19 PM
