| » Will not start - some lights out |
Model Number: MDBTT70AWB Brand: Maytag Age: 5 - 10 years
On touch pad:
Heavy, Light,Rinse,Insta, Auto, Delay,ToughScrub,High Temp buttons all work fine. Norm,Start/Cancel,HeatedDry,Sanitize will not light up Door switches test ok. Cleaned ribbon connector. Usually run washer on Normal then push Start. Does the touch pad wear out? How can I test it to see if buttons are working? Thanks, Mark Ads By Google Related Models |
Replacement parts for MAYTAG MDBTT70AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com See the attachment for the tech sheet. Does the touch pad wear out? Yes but usually the unit wears out before the switches. But like anything else some do just fail. How can I test it to see if buttons are working? Yes see the tech sheet for the procedure. You will need a meter. The normal way to troubleshoot is to check the control pane (keypad), if it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
__________________
| Display Modes | |
| lights up no start | bobbyjoe | Dishwasher Repair | 1 | 05-30-2011 02:45 AM |
| Cycle lights on, but won't start | jmsaustx | Dishwasher Repair | 11 | 10-11-2010 08:30 PM |
| Will not start or any lights on panel | linda1331 | Dishwasher Repair | 0 | 06-29-2010 11:10 AM |
| Some Lights are on but wont start | vykefan4life | Dishwasher Repair | 9 | 12-30-2009 09:56 PM |
| Will not start led lights will not come on | samed38 | Washer Repair | 1 | 08-23-2009 04:19 PM |
