| » Water in the tub |
Model Number: SHU43C02UC/14 Brand: Bosch Age: 5 - 10 years
I started seeing water on the floor. I opened the door and found water in the tub. I figured the cycle got interrupted (which when you have a curious 2 year old running around isn't unusual). I turned the dishwasher on and it had 2 minutes left in the cycle. I canceled the cycle and let it drain. After sitting overnight (and no one running it) I opened up the door and there was water in the tub again. Also believe the door seal may need to be replaced. I have turned the water supply off and will let it it again to see if the water valve may be to blame. If anyone has any suggestions, please do share!
| Display Modes | |
| Fridge water dispenser water trickles out hear tapping sound (but makes ice) | Davidsgirl | Refrigerator & Freezer Repair | 5 | 03-28-2011 06:22 AM |
| Freezer stopped working, electrical arc or odor, & leaking water from water/ice line | elmwood | Refrigerator & Freezer Repair | 1 | 10-10-2010 08:25 AM |
| Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water | ugagrad04 | Refrigerator & Freezer Repair | 0 | 07-20-2010 06:43 PM |
| water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) | david465 | Refrigerator & Freezer Repair | 4 | 03-11-2010 04:12 PM |
| Whirlpool LA5300XM Cold water trickles, warm water flows properly | ajaysheetal | Washer Repair | 2 | 02-14-2008 04:49 PM |
