Discuss
kitchen aid dishwasher malfunction
 in
Dishwasher Repair
well, here we go again as i acquired a partial helpful response upon my intiail inquiry for resolution. From the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » kitchen aid dishwasher malfunction
  #1 (permalink)
Old 07-27-2011, 06:06 AM
Junior Member
paulclark is on a distinguished road
Default kitchen aid dishwasher malfunction
Brand: Kitchen Aid   Age: 5 - 10 years
well, here we go again as i acquired a partial helpful response upon my intiail inquiry for resolution. From the start so nothing can be omitted as i am unable to assure myself a connection from the previous thread/subject the other day.
kitchenaid dishwasher, model kuds01Ijbso, serial number fm1428810,
type 577-0, stainless steel. a week ago the unit burned out at the fuse, so i ordered a fuse locally and placed within however this time burned out at fuse and control box assembly, therefore ordered your replacement fuse and control box assembly part number AP3775964. Started up unit, did not finish cycle, as it did not drain. Took apart interior and checked for debris for possbile blockage, minor debris, lights work for numbers "1and2" but also get horizontal ---- lines across panel. Took your advise whereby cleaned ribbon taping with alcohol and vaseline, started up, motor engaging, however again stopped prematurely as it did not drain again.
disassembled unit, check for further blockage within tubing underneath pump, no blockage, tubing blows through fine.
upon your response upon my initial you wanted the complete model number and serial for further trouble shooting and suggested checking for discharge of water to a bucket. HOw can that be possible if it does not drain?
i'm thinking it is either the control console assemble part # AP3138258 which is not communicating to the pump motor, or the motor itself which may be defective part# AP3133590.
would greatly appreciate a thorough intelligent productive response and not a copy and past as dishes are adding up and taking over the kitchen.
please copy my entire inquilre and respond to me both here in forum and at my work email address at paul.clark@dcma.mil
thanks,
paul clark
cell 781 254 6437
Ads By Google
  #2 (permalink)
Old 07-29-2011, 08:32 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
[quote=paulclark;494935]well, here we go again as i acquired a partial helpful response upon my intiail inquiry for resolution. From the start so nothing can be omitted as i am unable to assure myself a connection from the previous thread/subject the other day.
thanks,
paul c.
As I understand this, Everything is now working properly, but the dishwasher does not drain, is that correct ?
Do you have access to a VOM / multimeter, [AP3873826] so you can check the drain pump motor winding resistance, and voltage to the motor, from the control board ?
The drain pump motor should have a resistance of 16 ohms(+/- 10%) across the two terminals of the motor with the wires disconnected.
As long as the wires are disconnected, you can insert your meter probes into the end of the two wire terminals, Start the dishwasher, then cancel the cycle a few seconds later. The dishwasher should program into a 2 minute drain cycle . At that point, if the control board and wiring are in tact, there should be 120 VAC across the two wires.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dishwasher malfunction kelpat Dishwasher Repair 1 04-13-2009 12:00 PM
Whirlpool dishwasher malfunction rick Dishwasher Repair 2 03-03-2009 08:14 AM
kenmore dishwasher malfunction kelpat Dishwasher Repair 1 02-15-2009 07:47 AM
dishwasher malfunction markandcindy Dishwasher Repair 1 09-29-2008 03:34 PM
Dishwasher Software Malfunction? ships380 Dishwasher Repair 2 11-19-2007 09:27 AM
