chawlick
#1 Posted : Sunday, March 22, 2009 3:47:50 PM(UTC)
chawlick
The Sanitized light is blinking after the dishwasher is finished. The dishes are clean but very wet. Any idea what is wrong?
kayakcrzy
#2 Posted : Sunday, March 22, 2009 4:07:32 PM(UTC)
kayakcrzy
Could very well be a bad drying element. Tom
#3 Posted : Sunday, March 22, 2009 5:46:34 PM(UTC)
Replacement parts for WHIRLPOOL GU1200XTKQ0 | AppliancePartsPros.com
Here is a service manual
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Check the heater and the high limit thermostat
If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
