Discuss
Drain Pump keeps running
 in
Dishwasher Repair
Our dishwasher thinks there is water in it when it's empty. It is turning itself on also. Disconnected drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain Pump keeps running
  #1 (permalink)
Old 11-21-2007, 04:26 PM
WaltG WaltG is offline
Junior Member
WaltG is on a distinguished road
Default Drain Pump keeps running
Model Number: SHX46A05UC/30   Brand: Bosch   Age: 1 - 5 years
Our dishwasher thinks there is water in it when it's empty. It is turning itself on also. Disconnected drain hose from the garbage disposal and put water in the bottom of the dishwasher. Turned it on and kept feeding it water to try to change to the next cycle, no luck. Turned the circuit breaker off for 10 minutes. Tried the drain cancel, no luck. Was able to change cycles but pump kept on pumping. Help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-08-2008, 01:06 PM
gilbert ratchet gilbert ratchet is offline
Junior Member
gilbert ratchet is on a distinguished road
Default Any luck?
Sounds like I have the same trouble with a similar age Bosch DW in the UK. Did you manage to fix it?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy washer drain pump? mehullica Washer Repair 1 10-28-2007 02:04 PM
Fan running taylor Refrigerator & Freezer Repair 3 10-06-2007 04:06 AM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Drain Pump loadster Dishwasher Repair 1 08-07-2007 07:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
