Discuss
Motor runs but no water
 in
Dishwasher Repair
The motor seems to be running but I do not get water in the dishwasher Related Models Frigidaire  61-1120-10-00  Tap(v1)
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Motor runs but no water
  #1 (permalink)
Old 07-24-2011, 08:14 AM
Junior Member
barbarastjohn is on a distinguished road
Default Motor runs but no water
Model Number: 61-1120-10   Brand: Tappan   Age: More than 10 years
Related Models
Frigidaire 61-1120-10-00 Tap(v1) / 24 " Built - in Dishwasher
Frigidaire 61-1120-23 Tap(v3) / 24 " Built - in Dishwasher
Frigidaire 61-1127-10-00 Tap(v1) / Undercounter Dishwasher
Frigidaire 61-1137-10-00 Tap(v2) / Undercounter Dishwasher
Frigidaire 61-1140-00 Tap(v2) / 24 " Built - in Dishwasher
Frigidaire 61-1140-10-00 Tap(v1) / 24 " Built - in Dishwasher
Frigidaire 61-1140-23 Tap(v3) / 24 " Built - in Dishwasher
Frigidaire 61-1147-00-10 Tap(v3) / Undercounter Dishwasher
Frigidaire 61-1157-10-00 Tap(v4) / Undercounter Dishwasher
Frigidaire 61-1160-00 Tap(v2) / 24 " Built - in Dishwasher
Frigidaire 61-1160-10-00 Tap(v1) / 24 " Built - in Dishwasher
Frigidaire 61-1160-23 Tap(v3) / 24 " Built - in Dishwasher
Frigidaire 61-1170-00 Tap(v2) / 24 " Built - in Dishwasher
Frigidaire 61-1170-10-00 Tap(v1) / 24 " Built - in Dishwasher
Amana 610.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 610.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 610.002 MWAVE - FAMILY SIZE (60 HZ)
Maytag 61004752 MISC / ACCESSORY
Maytag 61004753 MISC / ACCESSORY
Maytag 61004754 MISC / ACCESSORY
Maytag 61004755 MISC / ACCESSORY
Maytag 61004756 MISC / ACCESSORY
Magic Chef 6100PRA RANGE- S/I STD GAS
Magic Chef 6100PRW RANGE- S/I STD GAS
Magic Chef 6100PTA RANGE- S/I STD GAS
Magic Chef 6100PTW RANGE- S/I STD GAS
Amana 614-2N ROOM AIR CONDITIONER
Amana 614-2P ROOM AIR CONDITIONER
Amana 614-2W ROOM AIR CONDITIONER
Amana 615-2F ROOM AIR CONDITIONER
Amana 615-2G ROOM AIR CONDITIONER
Amana 615-2J ROOM AIR CONDITIONER
Magic Chef 6157WRA RANGE- S/I STD GAS
Magic Chef 6157WRW RANGE- S/I STD GAS
Magic Chef 6157WTA RANGE- S/I STD GAS
Magic Chef 6157WTV RANGE- S/I STD GAS
Magic Chef 6157WTW RANGE- S/I STD GAS
Magic Chef 6157WUA RANGE- S/I STD GAS
Magic Chef 6157WUW RANGE- S/I STD GAS
Magic Chef 6157XRA RANGE- S/I STD GAS
Magic Chef 6157XRW RANGE- S/I STD GAS
Magic Chef 6157XTA RANGE- S/I STD GAS
Magic Chef 6157XTW RANGE- S/I STD GAS
Magic Chef 6157XUA RANGE- S/I STD GAS
Magic Chef 6157XUW RANGE- S/I STD GAS
Amana 619-3P ROOM AIR CONDITIONER
Amana 619-3W ROOM AIR CONDITIONER
Maytag 61C DRYER- GAS
Magic Chef 61HA-1 RANGE- S/I STD GAS
Magic Chef 61HA-3KW RANGE- S/I STD GAS
Magic Chef 61HA-3KX RANGE- S/I STD GAS
Magic Chef 61HN-1 RANGE- S/I STD GAS
Magic Chef 61HN-3KW RANGE- S/I STD GAS
Magic Chef 61HN-3KX RANGE- S/I STD GAS
Magic Chef 61HY-1 RANGE- S/I STD GAS
Magic Chef 61HY-3KW RANGE- S/I STD GAS
Magic Chef 61HY-3KX RANGE- S/I STD GAS
Magic Chef 61S04PAA RANGE- S/I STD GAS
Magic Chef 61S04PAW RANGE- S/I STD GAS
Magic Chef 61S14WAA RANGE- S/I STD GAS
Magic Chef 61S14WAW RANGE- S/I STD GAS
Magic Chef 61S14XAA RANGE- S/I STD GAS
Magic Chef 61S14XAB RANGE- S/I STD GAS
Magic Chef 61S14XAW RANGE- S/I STD GAS
Maytag 61W DRYER- GAS
Hoover 62
Frigidaire 6207B AUTOMATIC WASHER
Frigidaire 6208A WASHER
Amana 621-3F ROOM AIR CONDITIONER
Amana 621-3G ROOM AIR CONDITIONER
Amana 621-3J ROOM AIR CONDITIONER
Amana 621-3J-1 ROOM AIR CONDITIONER
Amana 621-5F ROOM AIR CONDITIONER
Amana 621-5G ROOM AIR CONDITIONER
Amana 621-5G-1 ROOM AIR CONDITIONER
Amana 621-5J ROOM AIR CONDITIONER
Amana 621.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 621.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 6221338550 TRASH COMPACTOR
Kenmore 6221358550 TRASH COMPACTOR
Kenmore 6221388550 TRASH COMPACTOR
Kenmore 62260002600 KENMORE COOKING
Kenmore 62260003600 KENMORE COOKING
Kenmore 62260008600 KENMORE COOKING
Kenmore 62260009600 KENMORE COOKING
Kenmore 6228369301NZ KENMORE COMPACTOR
Kenmore 6228415001NO SEARS COMPACTOR
Kenmore 6228416001GO KENMORE COMPACTOR
Kenmore 62284169900 SEARS COMPACTOR
Kenmore 6228419001GO KENMORE COMPACTOR
Kenmore 62284199910 KENMORE COMPACTOR
Kenmore 62284199920 SEARS COMPACTOR
Amana 624-3F ROOM AIR CONDITIONER
Amana 624-3FH ROOM AIR CONDITIONER
Amana 624-3G ROOM AIR CONDITIONER
Amana 624-3GH ROOM AIR CONDITIONER
Amana 624-3HW ROOM AIR CONDITIONER
Amana 624-3J ROOM AIR CONDITIONER
Amana 624-3J-1 ROOM AIR CONDITIONER
Amana 624-3JH ROOM AIR CONDITIONER
  #2 (permalink)
Old 07-24-2011, 06:58 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for FRIGIDAIRE 61-1120-10-00 Tap(v1) / 24 " Built - in Dishwasher | AppliancePartsPros.com
Check the float (Item 26 in Section 4) on the overfill assembly. Sometimes it can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve (item 3 in Section 6) when it should be on.
If there is no voltage, check across the fill valve/overfill switch (they are wired in series).
If there is no voltage there, then the control is probably toast.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor runs but the ram doesn't come up mpswin Trash Compactor Repair 0 07-26-2010 08:54 PM
Bosch dishwasher motor runs but no water comes out macguide Dishwasher Repair 0 02-21-2009 12:00 PM
Motor runs only for a moment cmickey Dishwasher Repair 0 09-18-2008 02:50 PM
Motor Runs but No Water ndquale Dishwasher Repair 2 06-19-2008 09:05 PM
RV w/d motor will not run CW. runs CCW OK qqkq Washer Repair 1 01-03-2008 12:02 PM
