| » wont fill is it the fill valve |
Model Number: shu3004-1 Brand: Whirlpool Age: 5 - 10 years
it works if you fill it manually took the valve off and the solenoid wont open the valve not sure about the control timer
Related Models |
Here is the parts breakdown
Replacement parts for WHIRLPOOL SHU30041 | AppliancePartsPros.com it works if you fill it manually I assume you mean that the dishwasher runs OK if filled manually took the valve off and the solenoid wont open the valve not sure about the control timer As long as you are sure the valve is not opening I would replace it. As far as the controller, measure the voltage at the valve wires when the unit should be filling with a meter. Should be 120 volts.
__________________
| Display Modes | |
| Low voltage on solenoid water fill valve | gv1941 | Dishwasher Repair | 1 | 03-01-2009 08:24 PM |
| No power to fill valve | rumney11 | Dishwasher Repair | 0 | 07-23-2008 02:43 PM |
| How can I test a fill valve? | geoghegan | Dishwasher Repair | 1 | 01-31-2008 08:41 PM |
| No Power to fill valve | dpk1000 | Dishwasher Repair | 2 | 09-13-2007 08:57 PM |
| Ice maker still leaking - Just replaced fill valve | Adam80 | Refrigerator & Freezer Repair | 1 | 09-12-2007 08:09 PM |
