Discuss
Fred
 in
Dishwasher Repair
Unit does not appear to pump water. Contol knob when turned appears (i.e. the sounds that come from the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Fred
  #1 (permalink)
Old 11-19-2007, 02:35 PM
wilkerson wilkerson is offline
Junior Member
wilkerson is on a distinguished road
Default Fred
Model Number: GSD1200T03XX   Brand: GE   Age: 5 - 10 years
Unit does not appear to pump water. Contol knob when turned appears (i.e. the sounds that come from the dishwasher) to be activating other functions. Heating coil warms. I have checked the float. Do I need to replace teh water pump and motor? Is this a very difficult repair?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-19-2007, 02:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If the motor does not run but makes a humming noise then the pump got stuck.
You have two options: try to rebuild the old pump or to replace the whole pump and motor assembly.
In order to fix the dishwasher it has to be removed from the cabinet.
The pump and motor assembly has to be removed from the dishwasher in both scenarios.
The impeller and seal kit (to rebuild the old pump) and the new pump and motor assembly are coming with the complete installation instructions.
- The part number for the pump and motor assembly AP2616850
- The part number for the impeller and seal kit AP631386
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
