| » dishwasher |
Model Number: gsd3420z02bb Brand: GE Age: 5 - 10 years
door leaking slightly at bottom right corner, leaves white powder stain on kitchen floor with radiant heat in cement.
i relaced door gasket and bottom corner inserts in the body i did not relace center piece in bottom of door also dishes not always clean is there a check/drain valve in washer assy and where is it located Ads By Google Related Models |
Sometimes the lower spray arm will develop a crack and the water will spray directly out instead of up causing it to leak around the seals.
Make sure water level isn't too high after it fills. |
| Display Modes | |
