Our Kitchen Aid dishwasher continually blowing thermal fuses. I stopped the washer in mid cycle and tested the water temp. It is at the same temp as out of our water heater. Could the heating element be blown and is there a way to test?
Sounds like this is a reoccurring problem, is there a solution or something else I need to test
Thanks,
