Discuss
Whirlpool Quiet Partner ii clean light flashing - have reset, still flashing
 in
Dishwasher Repair
Originally Posted by DPForumDog Hello, My 9 yr Kitchen Aid DW has been stopping in mid cycle with the clean
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner ii clean light flashing - have reset, still flashing
  #41 (permalink)
Old 08-18-2014, 08:01 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by DPForumDog View Post
Hello,
My 9 yr Kitchen Aid DW has been stopping in mid cycle with the clean light blinking. For a while this only happened 2x a year, and resetting the control panel by this process ((close the soap dispenser door, close the dishwasher door, and toggle between hitting high temp scrub and energy save dry several times until all the leds light up, press cancel) this would allow a good restart and the DW would run fine for a while. But now toggling between the two buttons and restarting only works about 1 in 10 times. I have been accommodating this by washing, toggle/cancel/restarting wash with no soap to rinse the soap , but I have no dry.
I have placed a right side cup on the top shelf and it will fill up in just a few minutes so I have plenty of water.
The water is coming from the hot water heater. It seems a little colder than the tap but I think that is because it looses a little heat sloshing around in the DW. We did turn up the hot water heater but to me the dw water doesn't seem quite as hot as the tap.
I am about to try this...... "Youíd need to uninstall your dishwasher, disconnect power and lay it on itís back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if itís good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because thatís the one device you cannot test"
And I am going to try this ..... " There are 2 switches that close 2 circuits when you close the door. The one on the right side is not staying closed, thus the heating circuit is shutting down. An easy test is to trade the 2 wires on each switch to the other side. This should eliminate the clean light blinking and cause the dishwasher to just turn off. The newer designs have eliminated this double switch design"
Which should I try first? Or do you have any other ideas?
DPForumDog
Granny DP
8-2-2014
DPForumDog, Your first check should be to make sure the water temperature in the bottom of the tub is at least 120 dgrs.F. on the first fill of the cycle. You're correct, there is cold water left in the water supply line to the dishwasher, and once the dishwasher has filled and the water starts to circulate, the remaining water in the tub will loose temperature due to the circulation process.
What you may want to do is : run the hot water faucet at the kitchen sink until the water is hot (120 to 130 dgrs.) then start the dishwasher. Of course you want to reset the control board first, once the tub is full and starts to circulates then check the water temperature, again. If the water temperature is in range, and the cycle runs completely, and the clean LED doesn't flash or blink. you'll be fine. If the water temperature is in range, and the clean LED blinks, then it's time to check the heater resistance and hi limit thermostat.
You can usually find the wiring diagram and tech data sheet attached to the back of the kickplate assembly or attached to the frame work near the fill valve. You can check the heater resistance, and hi limit thermostat at the control board connectors, instead of removing the dishwasher from the cabinet. Just make sure you remove power to the dishwasher before you do anything.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #42 (permalink)
Old 09-07-2015, 08:58 AM
Junior Member
Brian O'Dea is on a distinguished road
Default Quiet Partner II clean light blinks 7 times, external water temp should be ok
I'm new to the Forum. I have a Whirlpool Quiet Partner II as well with the same "clean light blinks 7 times symptom".
For one post, Joe M. replied "You need to make sure, the water temperature, in the bottom of the tub, on the first fill of a wash cycle, is at least 120 to 130 dgrs. F. (you should be able to run the hot water faucet at the kitchen sink, and get somewhere in that range, before you start the dishwasher).
If this doesn't solve the problem, drop us a line and we can walk you through the test procedures for the heater circuit and components.
Read more: Whirlpool Quiet Partner ii clean light flashing - have reset, still flashing
Appliance Repair Forum - Free Service from Appliance Parts Pros "
I've raised the hot water temperature to ensure that the water is at least 120 to 130 deg F. Note that before I raised it, it was just at 120 [and apparently worked fine at that temp for months]. The problem still happens, though not every time. I'll note that even when the problem doesn't happen, the dishes, particularly the silverware can still be dirty. Further, when the problem does happen, it doesn't happen near the start of the wash.
I have cleaned out the filter at the bottom and manually removed gunk (multiple times) but that doesn't seem to change the frequency with which the issue arises.
I'm interested in any other thoughts including "...we can walk you through the test procedures for the heater circuit and components."
Thanks,
Brian
  #43 (permalink)
Old 09-24-2015, 06:45 AM
Senior Expert
Default
Brian,
To circuit check the heater circuit located on the bottom of the dishwasher tub. You'll need to remove power to the dishwasher, remove the kickplate and lower access panel so you can access the terminals on the heater and hi limit thermostat.
Label and disconnect the wires attached to the heater element terminals, place the meter leads, across the terminals and you should have a resistance reading of 10 to 35 ohms, if the heater is "good". Reattach the wires to the heater, if all's OK, disconnect the wires from the high limit thermostat, pl​a​ce the meter leads across the thermosta​t​ terminals, you should have a "closed"(infinite resistance) circuit across the terminals at room temperature(below 140 dgrs.).
If all checks are OK, or in range, You will need to check the heater circuit at the control board( you didn't include a specific model number). You'll need to check for the 10 to 35 ohms resistance at the control board connector, to determine if the circuit is "complete" and replace the control board, if that's the case.
You do want to verify the water temperature in the tub, on the first fill. it needs to be a minimum of 120 dgrs. F. in the bottom of the tub, when the motor starts to wash. (the hotter, the better). The control board has a maximum amount of time to increase the water temperature to 140 dgrs.F.) if the control board does not see the circuit, resistance, etc. the "clean" light will flash 7 times.
__________________
Joe M. APP TEAM
  #44 (permalink)
Old 03-13-2016, 07:47 AM
Junior Member
mlcar1 is on a distinguished road
Default same problem, now fixed
Hi-I found this thread when my Quiet Partner II started having the same problem with the flashing lights. I entered the secret code, ran it without detergent, and have run 2 normal cycles since then with no problem.
Thank you so much for your help!!
Molly
  #45 (permalink)
Old 03-14-2016, 06:12 AM
Senior Expert
Default
Molly
Molly, You're Very Welcome !!! We're glad it worked for you. Thanks
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Quiet Partner I normal light flashing armstrongv Dishwasher Repair 1 03-04-2011 02:51 PM
Whirlpool Quiet Partner III dead "Clean xpress" light flashing flyboy3633 Dishwasher Repair 0 07-24-2010 04:47 PM
Whirlpool Quiet Partner IV flashing LED 2 RTP Dishwasher Repair 0 04-28-2010 07:15 PM
Whirlpool Quiet Partner 3 Soak&Scour Flashing YellowJeep Dishwasher Repair 5 03-25-2010 02:08 AM
quiet partner III soak and scour light flashing dbout Dishwasher Repair 0 06-27-2008 05:37 PM
