Discuss
Maytag Dishwasher won't start
 in
Dishwasher Repair
After 4 years of almost daily use, my MDB7601AWB will not start. We can select the cycle: The time then
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Dishwasher won't start
  #1 (permalink)
Old 07-04-2011, 09:01 PM
Junior Member
k5wls is on a distinguished road
Default Maytag Dishwasher won't start
Model Number: MDB7601AWB   Brand: Maytag   Age: 1 - 5 years
The time then appears flashing on the front panel, waiting for you to close the door and press <Start>:
Nothing happens, however when you push either button on the front panel, <Start> or <Delay>. Since that is the exact same way it acts when the door is open, I pulled the connectors from both door switches and tested them first. Both are working normally.
I found the gasket that seals the steam vent to the outer door shell was off-center when the door was assembled:
This would have allowed steam to enter the door cavity on every wash cycle. There is some evidence of the effects from the steam inside the door: The foam paper insulation is drooping on that side from being wet and heavy:
And the thick insulation foam strip (PN AP4263539) has deformed, separated from the door and is also drooping down:
I cleaned the ends on both of the ribbon cables:
But the problem persists. Is there anything else I can check? Thanks in advance for your assistance!
[SIDEBAR: The steam vent gasket problem was probably initiated a year or two ago when a repairman came out to take care of recall work. I think the inside door panel and the control board were replaced due to fire concerns. That visit probably created this problem. Not that it makes a difference today...]
Ads By Google
Related Models
Maytag MDB7601AWB Dishwasher - Undercounter
Maytag MDB7601AWQ Dishwasher - Undercounter
Maytag MDB7601AWS Dishwasher - Undercounter
Maytag MDB7601AWW Dishwasher - Undercounter
Maytag MDB7650AWB Dishwasher - Undercounter
Maytag MDB7650AWQ Dishwasher - Undercounter
Maytag MDB7650AWS Dishwasher - Undercounter
Maytag MDB7650AWW Dishwasher - Undercounter
Maytag MDB7750AWB Dishwasher - Undercounter
Maytag MDB7750AWQ Dishwasher - Undercounter
Maytag MDB7750AWS Dishwasher - Undercounter
Maytag MDB7750AWW Dishwasher - Undercounter
Maytag MDB7751AWB Dishwasher - Undercounter
Maytag MDB7751AWQ Dishwasher - Undercounter
Maytag MDB7751AWS Dishwasher - Undercounter
Maytag MDB7751AWW Dishwasher - Undercounter
Maytag MDB7755AWB Dishwasher - Undercounter
Maytag MDB7755AWQ Dishwasher - Undercounter
Maytag MDB7755AWS Dishwasher - Undercounter
Maytag MDB7755AWW Dishwasher - Undercounter
Maytag MDB8000AWA Dishwasher - Undercounter
Maytag MDB8000AWB Dishwasher - Undercounter
Maytag MDB8000AWW Dishwasher - Undercounter
Maytag MDB8600AWB Dishwasher - Undercounter
Maytag MDB8600AWQ Dishwasher - Undercounter
Maytag MDB8600AWS Dishwasher - Undercounter
Maytag MDB8600AWW Dishwasher - Undercounter
Maytag MDB8601AWB10 Undercounter Dishwasher
Maytag MDB8601AWS10 Undercounter Dishwasher
Maytag MDB8601AWW10 Undercounter Dishwasher
Maytag MDB8750AWB Dishwasher - Undercounter
Maytag MDB8750AWQ Dishwasher - Undercounter
Maytag MDB8750AWS Dishwasher - Undercounter
Maytag MDB8750AWW Dishwasher - Undercounter
Maytag MDB8751AWB Dishwasher - Undercounter
Maytag MDB8751AWQ Dishwasher - Undercounter
Maytag MDB8751AWS Dishwasher - Undercounter
Maytag MDB8751AWW Dishwasher - Undercounter
Maytag MDB8751BWB Dishwasher - Undercounter
Maytag MDB8751BWQ Dishwasher - Undercounter
Maytag MDB8751BWS Dishwasher - Undercounter
Maytag MDB8751BWW Dishwasher - Undercounter
Maytag MDB8851AWB10 Undercounter Dishwasher
Maytag MDB8851AWS10 Undercounter Dishwasher
Maytag MDB8851AWW10 Undercounter Dishwasher
Maytag MDB8951AWB Dishwasher - Undercounter
Maytag MDB8951AWQ Dishwasher - Undercounter
Maytag MDB8951AWS Dishwasher - Undercounter
Maytag MDB8951AWW Dishwasher - Undercounter
Maytag MDB8951BWB10 Undercounter Dishwasher
Maytag MDB8951BWQ10 Undercounter Dishwasher
Maytag MDB8951BWS10 Undercounter Dishwasher
Maytag MDB8951BWW10 Undercounter Dishwasher
Maytag MDB9000AWB Dishwasher - Undercounter
Maytag MDB9000AWW Dishwasher - Undercounter
Maytag MDB9100AWA Dishwasher - Undercounter
Maytag MDB9100AWB Dishwasher - Undercounter
Maytag MDB9100AWQ Dishwasher - Undercounter
Maytag MDB9100AWS Dishwasher - Undercounter
Maytag MDB9100AWW Dishwasher - Undercounter
Maytag MDB9150AWB Dishwasher - Undercounter
Maytag MDB9150AWQ Dishwasher - Undercounter
Maytag MDB9150AWS Dishwasher - Undercounter
Maytag MDB9150AWW Dishwasher - Undercounter
Maytag MDB9600AWB Dishwasher - Undercounter
Maytag MDB9600AWQ Dishwasher - Undercounter
Maytag MDB9600AWS Dishwasher - Undercounter
Maytag MDB9600AWW Dishwasher - Undercounter
Maytag MDB9601AWB Dishwasher - Undercounter
Maytag MDB9601AWQ Dishwasher - Undercounter
Maytag MDB9601AWS Dishwasher - Undercounter
Maytag MDB9601AWW Dishwasher - Undercounter
Maytag MDB9750AWB Dishwasher - Undercounter
Maytag MDB9750AWQ Dishwasher - Undercounter
Maytag MDB9750AWS Dishwasher - Undercounter
Maytag MDB9750AWW Dishwasher - Undercounter
Maytag MDB9750BWB10 Undercounter Dishwasher
Maytag MDB9750BWS10 Undercounter Dishwasher
Maytag MDB9750BWW10 Undercounter Dishwasher
Maytag MDBCUBEAWX Dishwasher Cube
Maytag MDBD820AWB Dishwasher - Undercounter
Maytag MDBD820AWW Dishwasher - Undercounter
Maytag MDBD850AWB Dishwasher - Undercounter
Maytag MDBD850AWQ Dishwasher - Undercounter
Maytag MDBD850AWW Dishwasher - Undercounter
Maytag MDBD880AWB Dishwasher - Undercounter
Maytag MDBD880AWQ Dishwasher - Undercounter
Maytag MDBD880AWW Dishwasher - Undercounter
Maytag MDBE790AWB Dishwasher - Undercounter
Maytag MDBE790AWQ Dishwasher - Undercounter
Maytag MDBE790AWS Dishwasher - Undercounter
Maytag MDBE790AWW Dishwasher - Undercounter
Maytag MDBF550AWB Dishwasher - Undercounter
Maytag MDBF550AWQ Dishwasher - Undercounter
Maytag MDBF550AWW Dishwasher - Undercounter
Maytag MDBF750AWB Dishwasher - Undercounter
Maytag MDBF750AWQ Dishwasher - Undercounter
Maytag MDBF750AWS Dishwasher - Undercounter
Maytag MDBF750AWW Dishwasher - Undercounter
Maytag MDBH750AWB Dishwasher - Undercounter
Maytag MDBH750AWQ Dishwasher - Undercounter
Maytag MDBH750AWS Dishwasher - Undercounter
Maytag MDBH750AWW Dishwasher - Undercounter
Maytag MDBH940AWB Dishwasher - Undercounter
Maytag MDBH940AWS Dishwasher - Undercounter
Maytag MDBH940AWW Dishwasher - Undercounter
Maytag MDBH945AWB Dishwasher - Undercounter
Maytag MDBH945AWQ Dishwasher - Undercounter
Maytag MDBH945AWS Dishwasher - Undercounter
Maytag MDBH945AWW Dishwasher - Undercounter
Maytag MDBH950AWB Dishwasher - Undercounter
Maytag MDBH950AWQ Dishwasher - Undercounter
Maytag MDBH950AWS Dishwasher - Undercounter
Maytag MDBH950AWW Dishwasher - Undercounter
Maytag MDBH955AWB Dishwasher - Undercounter
Maytag MDBH955AWQ Dishwasher - Undercounter
Maytag MDBH955AWS Dishwasher - Undercounter
Maytag MDBH955AWW Dishwasher - Undercounter
Maytag MDBH965AWB 30" Electric Freestanding Standard Clean Range
Maytag MDBH965AWQ Dishwasher - Undercounter
  #2 (permalink)
Old 07-05-2011, 07:53 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
K5wls,
The first place to start,
Circuit test the touchpad buttons, on the front control panel according to the Tech Date Sheet on the back of the kick plate panel.
Did you use alcohol to clean the ribbon and connector, or the pencil eraser trick ?
Remember, once you've got the dishwasher repaired, Put a thin coat of di electric grease, or vaseline, on and around all the connectors(including the ribbons) to keep any moisture or contaminants out, you'll be fine from there on out.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-07-2011, 07:30 PM
Junior Member
Default
Thank you, Joe, for your prompt response, and thanks for letting me know about the testing information on the data sheet.
All of the buttons on the top edge of the door tested good. The <Start/Cancel> and the <Delay> buttons on the front both fail the test; they show as open even when pressed. I'm going to try spraying some contact cleaner in the slot where the ribbon cable enters into the front panel while working the buttons and then test again. Hey if steam can get in and ruin the contacts maybe the contact cleaner will have an impact.
I guess it must make sense to somebody to build both keypads into into a piece of the door so that the failure of a cheap contact switch requires the replacement of a $200 part, but it sure doesn't make sense to me!
I have some di-electric grease and won't forget to use it thanks to your comment. I really appreciate the assistance!
Rick
  #4 (permalink)
Old 07-08-2011, 06:28 AM
Senior Expert
Default
Rick
Rick,
Great Job.
Sometimes, cleaning the ribbon ends and the board connector, will "keep you going" for a while. Hope it'll work, But you're on top of it.
Assisting you is our pleasure, if you need more, drop us a line.
Thanks,
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 07-08-2011, 12:52 PM
Junior Member
nbees1 is on a distinguished road
Default same issue
I have a similar problem with my Maytag MDB7809AWQ2. How were you able to test the <Start/Cancel> and the <Delay> buttons on the front of the unit? Thankyou in advance
  #6 (permalink)
Old 07-08-2011, 03:32 PM
Senior Expert
Default
Quote:
Nbees,
You'll need to remove the lower access panel and kickplate from the front of the dishwasher. and search for the Tech Data Sheet, it's in a plastic envelope attached to the backside of the panel.
You'll turn the power off to the dishwasher, open the door and remove the screws across the top and the upper two(2) screws on the side of the inner door panel.
(you can also remove all the screws on the inner panel and remove the door outer panel and control panel, if you'd feel better).
You then disconnect the Keypad ribbon connector from the Printed circuit control board connector.
Using a multimeter,
Part number: AP3873826
and the data sheet, you will put the probes across the two(2) reccomended pins of the ribbon, press the appropriate button on the panel, and check for the proper resistance specified by the data sheet.
Improper, or no resistance would indicate a bad button/key pad,when pressed.
If the unit is "dead" no display, start, etc. you can also check the door switches and wiring, while you have the door apart.
Here's some meter usage information if you need it
How To Check Continuity With Ohmmeter
Good Luck,
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 07-09-2011, 06:57 AM
Junior Member
Default Maytag MDB7809AWQ2
Joe, Thanks you for the quick reply. I found the data sheet, I was able to test the door latch with the door closed. I was also able to test the control board by disconnecting the ribbbon cable from the key pad, then restore power the unit started the drain cycle. The LEDS on the key pad passed the test with the sevice diag. test. I tried the keyswitch resistance testing without success, even on a known good key/button would not measure any resistance. I thought I read somewhere that this tesy may not be valid for all keypads? Any ideas?
Thanks again
  #8 (permalink)
Old 07-11-2011, 06:13 AM
Senior Expert
Default
Thanks again
Nbees,
Yes, testing key pad ribbons can be a pain, and are not very reliable. A lot of people, don't test them anymore.
In general, with the information you supplied in your post, repalce the control panel/keypad assembly,
Part number: AP4456942
It's the most likely problem, at this point.
Good Luck,
__________________
Joe M. APP TEAM
  #9 (permalink)
Old 07-12-2011, 11:04 AM
Junior Member
Default Maytag Dish Washer
Joe, Thanks for your assistance I've replaced the control panel the unit is now operational.
  #10 (permalink)
Old 07-12-2011, 03:08 PM
Senior Expert
Default
Nbees,
Great, glad you're up and running.
Thanks for the update. It was my pleasure to help, and you did all the work.
Thanks,
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dishwasher won't start caroltdds Dishwasher Repair 1 06-05-2011 04:17 AM
Maytag dishwasher will not start lauranne Dishwasher Repair 3 03-28-2011 12:00 PM
Maytag Dishwasher Won't Start hmanka Dishwasher Repair 5 08-26-2010 07:07 AM
Maytag dishwasher will not start jsievert Dishwasher Repair 1 11-19-2009 05:41 AM
Maytag Dishwasher Won't Start Donw Dishwasher Repair 1 11-10-2008 09:38 PM
